This is a question from aquelty1:
Hallo Linus I gonna build a new pc soon Bot I have some problems with the parts
I got 900-950 USD to build for and i think of this:
MSI GeForce GTX 560Ti 1GB PhysX or AMD 6950
Gigabyte GA-990FXA-UD3, Socket-AM3+ or Gigabyte GA-970A-UD3, Socket-AM3+
Corsair TX V2 850W PSU
AMD Phenom II X4 955 Black Edition
Cooler Master HAF X Big Tower Sort
Kingston DDR3 HyperX 1600MHz 8GB or corsair
Samsung SpinPoint F3 500GB
And when i get the money I will buy a bulldozer and one more GPU and run SLI/crossfireX.
But I really need your I have ask on overclock and some other forums But thats not helped so I wanted to hear What you think How I can make a good gaming pc (im going to play BF3 on 1080p 22' to 24')
from a big fan! Who need help of the best youtuber!
I think you are spending too much on your power supply and your case considering the budget of your machine. If you had a $1500 budget, then I think those choices are okay, but if you cut down to a solid 650W power supply and a CM 690II or something like that, you would save enough money to get a GTX 570 or an Intel platform instead of what you've got now.
