Go Back   Hardware Canucks > HARDWARE CANUCKS COMMUNITY > LinusTechTips Q&A
Old December 29, 2011, 11:10 AM
Default h80
fan speed in bios doesnt update when I hit the button. any idea why this is?
Old January 3, 2012, 04:06 PM
Does anyone know if we need or can change the water fluid in the H100's or H80's?
Old January 3, 2012, 04:25 PM
no and why would you want to?
Old January 3, 2012, 06:45 PM
bigFOIG's Avatar
You can't and you don't need to. That's one of the benefits of those liquid cooling systems. No maintenance needed.
Back to the OP. I recommend compression fittings over barbs. They're a bit more expensive, but I think they're worth it. With barbs, you'll need something like hose clamps or zip ties to keep to tubing in place. With compression fittings, all you gotta to is tighten them and everything's good.
Old January 3, 2012, 08:02 PM
clamps... pfft i never did
Old January 4, 2012, 03:41 PM
anyone help me with this problem?
Old January 4, 2012, 04:44 PM
button for what?
Old January 4, 2012, 05:37 PM
KaptCrunch's Avatar
no speed sensor used on that channel
Originally Posted by enaberif View Post
button for what?
hardware or software
  #19 (permalink)
Old January 4, 2012, 09:27 PM
bigFOIG's Avatar
Or you can be a badass and use barbs without anything! Though you are risking a tube popping off and turning your watercooled system into an aquarium.
  #20 (permalink)
Old January 4, 2012, 10:03 PM
you obviously never put 7/16 on 1/2 barbs and tried taking it off.
[WTB] GTX 580 Beastylemon Buy/Sell & Trade 12 November 2, 2011 12:39 PM
H80 or H100 Reviews? PerryC Water Cooling 40 August 21, 2011 07:57 AM
[FS] Corsair XMS3 3X2GB 2000MHz, Corsair XMS3 3X2GB 1333MHz bombdigiti Buy/Sell & Trade 12 July 18, 2011 10:47 PM
Corsair Showcases Computer Build with the Corsair 800D and H50 FiXT Press Releases & Tech News 2 October 2, 2009 12:22 AM
