-   iPhone & iPods (http://www.hardwarecanucks.com/forum/iphone-ipods/)
-   -   Need Help - Gone from bad to worse (http://www.hardwarecanucks.com/forum/iphone-ipods/55420-need-help-gone-bad-worse.html)
Dunc July 11, 2012 07:51 AM
I posted about not being able to add an app.
Now, the iPod has lost (?) all but the defaults. I can see all the apps that should be loaded in C:\Users\[user]\My Music\iTunes\iTunes Media\Mobile Applications\ as .ipa files.
Numerous attempts to sync (via USB cable or Wi-Fi) achieve absolutely nothing.
Any suggestions? Thanks
o320 December 12, 2012 08:51 PM
You could use iExplorer to put all the apps onto your iPod. Then go on your iPod and install from there using a file viewer.
Good luck.
