Go Back   Hardware Canucks > Mac, iPhone & iPod > iPhone & iPods
Old August 27, 2012, 06:25 AM
Default Unfortunately...
My big problem here is apps - some free, some paid.
Have not bothered with the songs side of iTunes.
There are a lot more apps in iTunes (apparently split into the 2 libraries) than there are installed on my iPod.
Old August 27, 2012, 08:19 PM
lowfat's Avatar
You can always re-download apps you've paid for. Doesn't matter if they are in iTunes or not. As long as they were purchased w/ your Apple ID account.
Old August 29, 2012, 04:20 PM
Default Thanks to all
Not exactly sure what I did (or did not do). Generally, just did the suggestions provided & something clicked.
Anyway, iPod is all de-bugged. All apps now installed & afaik working
