-   iPhone & iPods (https://www.hardwarecanucks.com/forum/iphone-ipods/)
-   -   Which bluetooth headset work with iphone 4? (https://www.hardwarecanucks.com/forum/iphone-ipods/43512-bluetooth-headset-work-iphone-4-a.html)
mckchun May 23, 2011 11:09 PM
Hi all, I need some advice here.
I have a Jabra BT3030 that doesnt work with iphone but works on my old cell.
Or maybe you guys know a fix?
I want a BT headset that is:
- comfortable
- long battery life preferrably
- <$40-50, I could go higher if necessary
- or similar to BT3030, which allows 3rd party earphones to be plugged in
thanks in advance
merdelfex July 9, 2012 12:23 AM
Currently I use the Jawbone, that is a good enough for its price and sound good. It is the best headset I have ever used.
