Go Back   Hardware Canucks > Mac, iPhone & iPod > iPhone & iPods
Old April 17, 2010, 06:28 PM
RBA RBA is offline
Default Transfer iPod music to iTunes on PC hard drive
I recently built a new computer with a new hard drive and want to transfer my collection of music from my iPod back to the iTunes program on my computer. Is there an easy free way to do this?? Sorry I'm not more up on this technology so that is why I'm asking. I don't want to have to rip all my music from CD's back on to my hard drive. Would appreciate some feed back. Thanks.
Old May 25, 2010, 07:27 PM
if you have a nano you can go to you ipod folder and click show hidden folders.(forget what menu its under..) or if you have an ipod touch you need two programs.
Iphone browser.
iphonebrowser - Project Hosting on Google Code
and God Father
http://users.otenet.gr/~dtou20/
first use iphone browser to get the songs onto your computer then use the godfather thing to rename them (as they will be all wierd named..)
Sources.
How To Rename Music Files from iTunes the Easy Way [Windows]
How to get music off an iPod Touch, iPhone in Windows - IPHONETOUCH.BLORGE
How to get music off your iPod - destraynor(dont think you need to disable services but you welcome to do so)
hopefully this helps you. this way might take a while though
Old May 25, 2010, 08:54 PM
belgolas's Avatar
Or just use iTunes and sync it back.
Sponsor a child!
Fight poverty.
Qoute by Perineum
"ID10T. I just BETCHA he's got 9 toolbars on his web browser right now."
Old May 26, 2010, 02:28 AM
Pelt's Avatar
That won't work, unless Itunes has undergone a major change lately. If your current Itunes library is blank and you connect an Ipod with music or no music doesn't matter. Itunes will ask you if you want to sync your Ipod with that Itunes library, which if their is no library means it will erase all the music off of your ipod.
So do not, under any circumstances sync your Ipod with music, to your Itunes with no library. Follow the guide above.
First thing you should do once you get this sorted out is back up your Itunes library. You can copy and past your library folder to a external hard drive (which is what I use for back up), or use Itunes back-up program which is under the advanced tab in the menu. If you use the Itunes back up make sure you have a crap load of DVD's, because it's the only media you can use for back up with Itunes.
Good luck.
http://lh4.ggpht.com/nightwarp/R7YQuMGt-JI/AAAAAAAADoQ/KVuthG6qJfE/s400/Supportourtroops-2.jpg
Old May 26, 2010, 06:51 PM
belgolas's Avatar
Well I know it transfers purchases from iTunes. But always have a back-up no matter what. I even have an off-site back-up through carbonite.
Sponsor a child!
Fight poverty.
Qoute by Perineum
Old May 26, 2010, 07:18 PM
Digikid's Avatar
This has always worked for me. After a reformat I just plug it in and voila! It transfer from my 8GB Ipod Touch to the PC.
Old May 26, 2010, 07:31 PM
Arinoth's Avatar
Have you bought all your music off of iTunes?
Old May 26, 2010, 07:41 PM
Digikid's Avatar
OH right....forgot about that.....
Yes I have to re-add my CD's. Thanks for the reminder of that.
Old May 26, 2010, 08:31 PM
belgolas's Avatar
Ya and thats why I don't like it because I'm locked in
Sponsor a child!
Fight poverty.
Qoute by Perineum
Old June 22, 2011, 08:18 PM
Default Transfer iPod music to iTunes library
Hello,
I'm sorry to tell you that Apple doesn't allow you to transfer your collection of music from your iPod back to the iTunes on your computer. But recently I found a program - iPod to iTunes Transfer, which can replace Apple iTunes to transfer all files back to iTunes easily.
It is easy to use. Though you are a newbie, you can operate it effortlessly. If you are still worried about the guide of how to use it, please refer to the article - Sync iPod to iTunes.
Going for new Hard drive apos2009 Storage 0 April 8, 2010 03:17 AM
How do I set my second hard drive as a "data drive"? lsquare Storage 11 March 19, 2010 09:11 PM
iTunes Transfer darkorb Networking 3 September 10, 2008 06:55 PM
Post your external drive enclosure transfer speeds. Cardboard box with DSL Storage 1 June 28, 2008 06:57 AM
iTunes Now Offering DRM-Free Music Tracks for $1.29 Babrbarossa Reviews & Articles from the Web 0 May 31, 2007 08:03 AM
