  #21 (permalink)
Old September 23, 2008, 10:45 AM
lowfat's Avatar
I don't know if you've seen my other thread with my case but I have 4 HDD's in the bay right next the PSU. It fits but it was damn hard to get all the connectors to fit.
Originally Posted by Lithotech View Post
You can see from this pic, that using the other two HD bays it is a bit of a pinch against the PSU. The cables from each will be mashing up against each other.
Pretty sure I read of people using a drive bay adapter and the second 5.25 bay for one HD.
Also looks like the lower HD bay in the tray by the mobo might collide with mobo components or sata connectors. Full size vid cards look to be out of the question if you mount a HD in that bay! Major PITA, one thing after another!
I am thinking it would be best to use a smaller ATX mobo like the gigabyte's, which are a bit narrower than a full ATX board. Would free up some space for connectors etc.
It's sad really, because it is otherwise an awesome case.
The only other thing I have seen that may work, puts the PSU over top of the CPU. Can't recall what case that was, will return and post if I come across it. I normally avoid such a situation, but if it allows more drives and longer vid cards, the tradeoff is easy if you just use a flower type zalman cooler.
  #22 (permalink)
Old September 23, 2008, 11:38 AM
Cptn Vortex's Avatar
Lol I didnt see the original date of this thread.
The Vortex H20
MSI Z77A-GD65
Intel i7 3770K @ 4.6GHZ 1.28v
Galaxy GTX 680 @ 1241MHZ
8GB Mushkin Blackline 1600MHZ 9-9-9-24 1.5v
Asus Xonar Essence STX
OCZ Z-Series GOLD 850W
2 x 128GB Corsair Force GT SATA3 SSD RAID0 :)
Acheiva Shimian Q270 Lite 2560x1440
Benq W500 Pojector.
Watercooling:
EK Supreme HF, EK FC GTX 680 Block, MCR320+Gelid Silent 12 Push/Pull, DD Pump, EK Multioption 100ml Res, EK Coolstream XT 220 RAD Gelid Wings Push/Pull.
  #23 (permalink)
Old September 23, 2008, 01:01 PM
Lithotech's Avatar
Gah! Me neither...
Less than a month tho... not too crusty.
eVGA 680i SLI (A1) P31
Intel Q6700 Kentsfield | Scythe Ninja-B | Antec Tri-Cool 80cfm
4GB (4x1024MB) Corsair Dominator 8500
boot: 4x WD Caviar SE16 250gb SATA2 Raid-0
backup: Seagate 500gb 32mb SATA2
eye: eVGA 9800GTX+ SC 512mb 770/2.25ghz
candy: Samsung 940B-HAS | X-Fi XMusic | Pioneer DVR-212D SATA
juice: PC Power & Cooling 750Quad | Cooler Master HAF932
steering: Logitech G15 & G5 | E3D Pro/Momo Wheel | X-530's
  #24 (permalink)
Old September 23, 2008, 01:04 PM
Lithotech's Avatar
Originally Posted by Cptn Vortex View Post
LowFat there is a new Antec Fusion coming out... Antec.com - Veris
Nice! Like a mini P180 on it's side, looks roomy.
  #25 (permalink)
Old September 23, 2008, 01:05 PM
Lithotech's Avatar
Just found it, the Word to the Wise thread, lol.
Nice job! They fit not bad at all! Can't see the sata connections to the mobo, how did that work out?
You find that everything is layered on top of each other? Have to dig your way down slowly to get at anything, then you start planning what is on top for what is most often accessed? Or am I alone when it comes to using a can opener to pack things into cases that are too small?
To hell with the cables, I still can't believe you got a rad in there!
Great, I think I can consider this case again, if the HDs fit then I am fine. The unit will fit nice in my a/v rack, the front bezel appeals to me.
  #26 (permalink)
Old September 23, 2008, 01:52 PM
lowfat's Avatar
It definitely was a pain that is for sure. I would of had significantly more room if I didn't watercool it. I am doing a rebuild here right away of it. This time only one videocard and no watercooling. The videocards overheated like mad before.
  #27 (permalink)
Old September 25, 2008, 10:29 AM
lcdguy's Avatar
damn you vortex. making me want to make another htpc and replace my beloved popcornhour. ugh maybe in the new year.
