Register Sweepstakes VB Image Host Members List LAN Calendar Search Today's Posts Mark Forums Read
LinkBack Thread Tools Search this Thread Display Modes
Old August 29, 2008, 03:34 PM
Level up: 40% Level up: 40% Level up: 40%
Level: 15 - 391 points to level up
Although it's not in this pic I have a Gigabyte 3850 installed now. Very happy with the case.
Amd FX60 @2.9
Asus A8R32-MVP Deluxe
2 Gig Corsair XMS 4000PT
2 Ati X1900's @XTX Speeds
2 WD 160gg HD's in Raid 0
XFi Platinum
Tt 680 Watt PSU
SATA Plextor DVD
(Liquid Cooled) Swiftech Apex Ultra and 2 MCW 60's
Kandalf
Old August 29, 2008, 03:59 PM
lowfat's Avatar
Level up: 2% Level up: 2% Level up: 2%
Level: 16 - 705 points to level up
It looks like I'll be able to watercool that just fine
Old August 29, 2008, 04:43 PM
Be sure to post that worklog....I've been pondering the idea myself.
Amd FX60 @2.9
XFi Platinum
Tt 680 Watt PSU
SATA Plextor DVD
Kandalf
Old August 29, 2008, 04:50 PM
Level: 23 - 897 points to level up
IF they were in stock
Ultimate CPU Cooling Solutions! USA
CSE: Lian-Li PC-A70
MOB: Biostar T-Power I45
CPU: Intel C2D E8600 @ 4.3ghz
RAM: 4gb g.skill pc2-8000
GPU: XFX 8800 GT Alpha Dog Edition
PSU: PC Power & Cooling 750w
Heatware: My Heatware
Old August 29, 2008, 05:05 PM
lowfat's Avatar
Originally Posted by enaberif View Post
Those look damned expensive.
Old August 29, 2008, 07:35 PM
NyteOwl's Avatar
Level up: 95% Level up: 95% Level up: 95%
Level: 9 - 12 points to level up
Check out the Coolermaster CM Media 282, only they can be hard to find in Canada.
Obsolescence is just a lack of imagination.
Old August 29, 2008, 07:56 PM
lowfat's Avatar
To me, it looks like a cheap mid-tower than can be laid on its side. Definitely do not like.
Old September 23, 2008, 10:57 AM
Lithotech's Avatar
Level up: 36% Level up: 36% Level up: 36%
Level: 13 - 314 points to level up
You can see from this pic, that using the other two HD bays it is a bit of a pinch against the PSU. The cables from each will be mashing up against each other.
Pretty sure I read of people using a drive bay adapter and the second 5.25 bay for one HD.
Also looks like the lower HD bay in the tray by the mobo might collide with mobo components or sata connectors. Full size vid cards look to be out of the question if you mount a HD in that bay! Major PITA, one thing after another!
I am thinking it would be best to use a smaller ATX mobo like the gigabyte's, which are a bit narrower than a full ATX board. Would free up some space for connectors etc.
It's sad really, because it is otherwise an awesome case.
The only other thing I have seen that may work, puts the PSU over top of the CPU. Can't recall what case that was, will return and post if I come across it. I normally avoid such a situation, but if it allows more drives and longer vid cards, the tradeoff is easy if you just use a flower type zalman cooler.
Originally Posted by cdn_Madrach View Post
Hey Lowfat here is my silverstone lascala LC17b.
eVGA 680i SLI (A1) P31
Intel E6750 Conroe 1333 G0 SLA9V L723B134 | Scythe Ninja-B | Antec Tri-Cool 80cfm
2x1024MB Crucial Ballistix Tracer 8500 | 5-5-5-15 1066mhz @1.9v
boot: 4x WD Caviar SE16 250gb SATA2 Raid-0
backup: Seagate 500gb 32mb SATA2
eye: eVGA 9800GTX+ SC 512mb 770/2.25ghz
candy: Samsung 940B-HAS | X-Fi XMusic | Pioneer DVR-212D SATA
juice: PC Power & Cooling 750Quad | Cooler Master HAF932
steering: Logitech G15 & G5 | E3D Pro/Momo Wheel | X-530's
  #19 (permalink)
Old September 23, 2008, 11:32 AM
Cptn Vortex's Avatar
Level up: 81% Level up: 81% Level up: 81%
Level: 21 - 240 points to level up
LowFat there is a new Antec Fusion coming out... Antec.com - Veris
The Vortex H20
Case....not sure what to call it
DFI X38 LT
Xeon X3210 @ 3.2GHZ 1.30V
PNY 9800GX2 (750/2200)
4GB Corsair Dominator 2x2gb kit DDR2 1066 5-5-5-15 2.0V
Ultra X3 1000W PSU
HT Omega Striker
2x500GB Hitachi RAID 0, 250 Seagate
Sharp 32" Aquos 1080p
Benq W500 1080i Pojector.
Watercooling:
Loop 1 - D-Tek Fuzion Quad Nozzle Bowed, MCR320+Zalman ZM-F3 Fans, MCP655, MCRES Micro.
Loop 2 - DB-1, DD 9800GX2 block, MCW30, MCR320, tLine res.
  #20 (permalink)
Old September 23, 2008, 11:42 AM
lowfat's Avatar
way too late as I bought the LC17 like a month ago
Forum Jump
Search this Thread:
Advanced Search
