Register Sweepstakes VB Image Host Members List LAN Calendar Search Today's Posts Mark Forums Read
LinkBack Thread Tools Search this Thread Display Modes
Old August 24, 2008, 10:51 AM
Level up: 14% Level up: 14% Level up: 14%
Level: 7 - 120 points to level up
Default Ok so I am tossing the htpc idea around....
We have a couple of new systems coming in (this week I hope ) and we'll have one older system that will be being replaced...
Asus something or another mobo (it's the misses machine and for teh life of me I can't remember what we put in there )
AMD Athon 2.41 Ghz CPU
Gig of ram
Nvidia 7800 GTX
Creative SB Auidigy
Assorted drives
Strong enough to build a htpc around do you think? I could see changing out the video to something more updated, that would allow 1080 (plan on getting a new tv this Christmas) as well, would like to be able to use it as a PVR and toss the VHS, and swap out the dvd rom for a BlueRay/DVD combo drive.
Would like to house it in a smaller case as well, something a little more compact than the Tusanmi Dream it is in now.
Enough here to build around?
Old August 24, 2008, 11:02 AM
Level up: 55% Level up: 55% Level up: 55%
Level: 15 - 291 points to level up
I built my HTPC for under $400.
asus m2n - hdmi
Athlon 3800+
1 gb kingston ram
320gb seagate
sata dvdrw
Antec minuet case.
Plays 1080p rips (.mkv) no problems.
Old August 24, 2008, 12:49 PM
Phobia's Avatar
Level up: 21% Level up: 21% Level up: 21%
Level: 11 - 266 points to level up
your video card should play 1080p. However i would suggest getting NCIX.com - Buy ASUS Radeon HD 3450 600MHZ 512MB 800MHZ DDR2 PCI-E DVI-I HDCP VGA HDTV Out Fanless Video Card - EAH3450/HTP/512M In Canada. . I have it and it plays my movies and everything fine. Plus if you use an HDMI cable it will play audio as well. So you will not need a reciever for the audio. It comes right out of the tv.
Mountain Mods u2 UFO
Intel qx9650 @ 4.2 ghz
4x1 gb corsair dominator 1066mhz
Asus p5e
Evga 9800GX2
Xp pro on 2 seagate 320 gb, raid 0
Vista Ultimate on 2 seagate 250 gb, raid 0
Corsair 1000HX
WC loop: mcp665, pa 120.2, dtek fuzion, DD 8800 gts full coverage, swiftech mcres-micro
Old August 24, 2008, 03:48 PM
Thanks for the replies peeps, greatly appreciated!
Old August 24, 2008, 04:29 PM
Level up: 80% Level up: 80% Level up: 80%
Level: 17 - 165 points to level up
I built my HTPC from my old socket 939 gear, it consists of:
AMD Athlon X2 4400+ (2.4GHz)
NVIDIA Geforce 7900GTO
2x1GB OCZ Platinum DDR-400
Old junky 80GB hard drive
Vista Ultimate 32bit
However I only use mine for playing back media, surfing the web and sometimes UT3. No PVR/Recording. Runs 1080p video flawlessly.
I don't think the Audigy has optical/coaxial digital outputs so if you have a 5.1 home-theater setup, then you'd be better off using just onboard sound (assuming it has digital outputs).
Xeon Quad X3350 | 3.40GHz (Damn X38 chipset)
ASUS Maximus Formula | BIOS RF0410
2GB Corsair Dominator | 850MHz
[/font]4-4-4-12-2T
2GB OCZ Platinum Rev2 | 850MHz 4-4-4-12-2T
HIS ICEQ4 Turbo HD4850 @ 700/1200
X-Fi XtremeMusic
Antec TruePower Quattro 850W
Antec 900
[ HEATWARE ]
Forum Jump
Search this Thread:
Advanced Search
