Old August 21, 2008, 01:44 PM
ChuckleBrother's Avatar
Level up: 56% Level up: 56% Level up: 56%
Level: 11 - 151 points to level up
Default Need a setup
Alright, so in my moms new house there is no way to run cable upstairs, and she isn't interested in drilling a hole in her floors. So my plan was to do it over the network(wireless N).
The HOW of it has me a bit confused though, I'm not entirely sure what hardware is good(need a tuner) nor do I know what software to use. Something that did catch my eye was Mythbuntu, and it DOES look good. So, each frontend has to be a pc, but does it need to be MUCH of a pc? Would an Atom or VIA board work just fine for one of these?
Also, what sort of control do the frontends have? Cause I use a remote like the one I have for Windows MCE?
If anyone has any advice I would greatly appreciate it, as well as a general idea of how the quality will be streamed over the network.
PS I want to have the ability to add multiple computers to this setup, so a dual tuner is a must(doesnt need to be HD though, we just have a standard set top box), if possible I want as many as 4 video streams at any one time.
"...you play a mean banjo"
My system: Haven
CPU: Core 2 Quad Q6600 @ 3.0Ghz | RAM: OCZ Platinum Rev.2 2x2Gb | Mobo: Asus P5KC | GPU: MSI 8800 Ultra | Case: Silverstone TJ09
Cooling: D-Tek FuZion v1 | Swiftech MCP655 | MCR120 | MCR220 | PA120.3 | EK-FC 8800 Ultra
Old August 21, 2008, 04:57 PM
Jack Rabbit's Avatar
Level up: 30% Level up: 30% Level up: 30%
Level: 12 - 283 points to level up
A good electrician can run cables anywhere. It would cost you but it can be done.
Check out the latest episode of Systm on Revion3 for all your MythTV answers.
Companion - E8400 - P5K SE - EN8600GT SILENT - 2x1G Ballistix (POS) - WD250 - X241W
Server - Q6600 - P5E WS Pro - EAH3450 - 4X2G Redline - WD250 - Pioneer DVD-212
On the shelf - P5N32-E SLI - BFG 8800GTS 640M OC2 - Ballistix 2x1G 8500 4-4-4-12 - X-Fi Fatal1ty - 1xWD 150 Raptor
Old August 21, 2008, 10:01 PM
Problem with that is that it doesn't migrate well, and she might not be living here very long, so being able to pack it all in will be a nice touch.
Price isn't a big deal since I already have the backend machine, and all its missing is the tuner card(s). Its already outfitted with 2tb of storage, so it should be okay for recording/etc.
Just don't know what quality tuners are...anyone know of a really nice dual tuner?
My system: Haven
Forum Jump
