If you open the ccc and go down to dtv then hdtv support you will see the choices for forced detection check off the ones you want forced and then apply the settings and see what happens. Boy i hope this works take care
I tried setting it to the "1080p60 standard ( 1920 x 1080 @ 60Hz )" and changing the input still results in a lost video signal. I've included a screenshot to show you what I did: ![]() After I seelcted the 1080p60 standard I pressed Apply Format, and then the main Apply button. I've also just tried having two profiles each with a slightly different resolution, and pressing the shortcuts for them after I've switched the input hoping the refresh in the resolution would solve the problem, but still nothing.
__________________ QX9650 @ ... | Asus P5Q-E |2x2GB Dominator @ ... VisionTek 4870 @ 825MHz/4.6Ghz|WD 640GB Black PCP&C 750W Silencer | HT Omega Claro X3350 @ 4187MHz Last edited by CanadaRox; July 2, 2008 at 08:03 PM. |
Do you have the same problem when it is set to a native resolution 1024x768 at 70 . If so i would suspect that there is a problem with your vga card(ouch). Because im using asus 3650 silent and set to the same settings with a 37 lg as you have shown check diplay options and make sure 3d refresh overide is disabled. I have tried recreate the same problem that your having but i cant seem to.
| Thread Tools | |
| Display Modes | |
