#1) try installing the CCCP (Combined Community Codec Pack) which has very good mkv codecs.
#2) Which version of windows are you running? If youre not running vista, the hybrid crossfire feature of your motherboard is NOT being used. Therefore, you might want to try it with Vista and enabled the Hybrid crossfire support, otherwise your 3450 is working alone and probably having difficulty.
Get back to us!
__________________ "Backed by common sense and physics!" -Squeetard |
