Old May 11, 2008, 10:04 PM
sswilson's Avatar
If you only plan to do "light" overclocking, I'd say that your primary cooling focus should be on the drives.
How about one of the coolermaster cases with a couple of their 5 1/4 bay 120mm fan HDD inserts? If you hunt around, you might even be able to find a "lan carry case" with handles to lug around a standard mid-tower case.
If it were me, I'd go with one of the new quads and judging by the latest trends here I'd suggest some Mushkin Ram paired with either an X38 / X48 chipset for intel, or 750i/790i for Nvidia motherboard.
Old May 12, 2008, 01:21 PM
cdn_Madrach's Avatar
The nicest looking sff case I know of is by Falcon north west (fragbox) Falcon Northwest Computer Systems, The Ultimate Gaming PCs. I believe you can just purchase the case. Also if I'm not mistaken it is a modded silverstone case.
Intel e8400
Asus P5q pro
Mushkin Redline 4gb
Silverstone Strider 1kw modular
4870x2
Ocz Vendetta 2
Top deck Tech Station
Samsung dvd
Old May 12, 2008, 02:33 PM
Cptn Vortex's Avatar
HA
Eurocom lets loose Quad Core XEON-based D901C PHANTOM-X server laptop - Engadget
The Vortex H20
MSI Z77A-GD65
Intel i7 3770K @ 4.6GHZ 1.28v
Galaxy GTX 680 @ 1241MHZ
8GB Mushkin Blackline 1600MHZ 9-9-9-24 1.5v
Asus Xonar Essence STX
OCZ Z-Series GOLD 850W
2 x 128GB Corsair Force GT SATA3 SSD RAID0 :)
Acheiva Shimian Q270 Lite 2560x1440
Benq W500 Pojector.
Watercooling:
EK Supreme HF, EK FC GTX 680 Block, MCR320+Gelid Silent 12 Push/Pull, DD Pump, EK Multioption 100ml Res, EK Coolstream XT 220 RAD Gelid Wings Push/Pull.
Old May 12, 2008, 02:58 PM
Sweet
Intel e8400
Asus P5q pro
Mushkin Redline 4gb
4870x2
Ocz Vendetta 2
Samsung dvd
