Old March 29, 2014, 12:12 PM
MARSTG's Avatar
Dancing_Banana add on card question
Guys I have a question for the HTPC world : you know those addon cards ( ADD2 ) that were used on the core 2 duo systems that were giving a DVI or HDMI connection, do they pass sound over the HDMI connection?
Old March 29, 2014, 12:19 PM
KaptCrunch's Avatar
what card if 2013 standard YES.... 1998 NO
Old March 29, 2014, 12:48 PM
MARSTG's Avatar
No need to be ironic, I said core 2 duo!
this kind of cards Amazon.com: HP DVI ADD2 Adapter Card - add-on interface board ( DY674A ): Electronics
Old March 29, 2014, 01:04 PM
Not 100% sure on this but I believe your motherboard must be capable of passing sound via the PCI-E if you want to pass sound by the video card. Usually this is an option in the BIOS. For my setup, I use the SPDIF pin out on the motherboard and pass it back to the video card to enable sound over DVI / HDMI.
Old March 29, 2014, 01:30 PM
sswilson's Avatar
Any chance this is the low profile version of the same card?
Amazon.com: HP Intel DVI-D ADD2 Sdvo PCI-E Adapter For DC7100(Low Profiie) 359301-003: Electronics
If so, one of the comments states that audio is not passed through via HDMI.
Old March 29, 2014, 01:41 PM
MARSTG's Avatar
actually the card I am talking about is a part of the accesories combo coming with the Jetway X Blue G45, shown here. Jetway - Tech.On The Move - Motherboard - XBLUE-G45
the card in the picture I saw a pic on newegg, can output HDMI and DP
for sswilson : I already know that G45/Q45 chipset is not passing audio through a dvi to hdmi adapter, already tried that. I guess I will give up on that idea then.
Old March 29, 2014, 01:59 PM
KaptCrunch's Avatar
THEY SHOW * and say may or not depends on manufactor for both video and audio rear I/O
Old March 29, 2014, 02:02 PM
KaptCrunch's Avatar
got a Nvidia i'msure if you add in NV gpu it will work with Nv drivers that got HDMI on card
TV Tuner Card Question irtehleet HTPC Systems & Software 12 March 23, 2012 07:22 AM
Question about sound card placement in relation to video card. QuiZNo Audio 5 January 18, 2012 02:58 PM
Vid Card Question BVickery Video Cards 12 November 9, 2011 02:15 PM
Question On a PhysX Card shayan288 Video Cards 13 October 29, 2010 02:26 PM
sound card question ultraman7k Audio 3 April 24, 2010 10:21 AM
