Old January 21, 2014, 11:11 AM
sakage.shinga's Avatar
Default HDMI-DP converter vs pure HDMI
Hi guys,
Just realized that my video card (HTPC build) has no HDMI outputs (4xDisplay Ports + 2xDVI). I was planning on connecting the rig to my Sony receiver via HDMI. So now I can either,
1) Get a HDMI-DP converter then connect using HDMI cable to receiver
2) Get a new video card and connect using HDMI cable to receiver
Obviously I'd prefer the former since it'd cost me like $10. However, I also don't want any image/audio quality loss, not to mention that I'd need that converter to still carry both audio/video signals across to the HDMI cable. Also would HDCP still work?
Thanks!
Photography/Gaming build: i7-4770K, NH-D14, Z87 Sabertooth, 16GB Ripjaws X, GTX 780 OC DirectCU II 3GB, M500 480GB, Caviar Black 2TB, Dual Red 4TBx2 (RAID 1), XFX Pro 850W 80+ Gold, Graphite Series 600T SE White
HTPC build: i5-750, Hyper 212+, P7P55D Pro, 8GB Ripjaws X, R6970 DirectCU II 2GB, Caviar Black 640GB/2TB, Caviar Green 3TB, Seagate Barracuda 3TB, Strider Plus 750W, CM 690 II Advanced
Mobile Media: Asus Transformer Infinity 32GB w/ keyboard dock
Old January 21, 2014, 11:43 AM
Rockfella's Avatar
Half ass connectivity option. Make shift HDMI never as good as real HDMI.
Old January 21, 2014, 11:59 AM
Arinoth's Avatar
I am currently using a DP to HDMI adapter and have no issues passing 1080p with audio to my receiver.
Here I am: here I remain
Old January 21, 2014, 12:13 PM
That's nice to know. Gonna pickup a converter today and try it out. Thanks!
Old January 21, 2014, 12:22 PM
DP = Digital
HDMI = Digital
Unless the DP to HDMI adapter is of crap quality you'll be fine.
Old January 21, 2014, 01:16 PM
SpaceSquad's Avatar
Originally Posted by enaberif View Post
DP = Digital
HDMI = Digital
Yup...As far as I know, they are incredibly similar...so I have no idea why an adapter would be an issue.
-Space
Old January 21, 2014, 01:52 PM
sswilson's Avatar
Doesn't DVI pass audio through a DVI - HDMI adapter as well?
Old January 21, 2014, 02:01 PM
Lpfan4ever's Avatar
Yep, has for a while now. I know for the 4 series ATI cards could do it natively, and the GTX200's needed the cable running from the video card header to the motherboard. Everything after that I believe is possible natively.
Originally Posted by encorp
Code:
<firebane> slightly used
Old January 21, 2014, 07:31 PM
Well the converter works. However, my 1080p Sony TV shrinks the HTPC desktop even though it's set at 1080p as well. I had to go into CCC and play with the stretch display area to overscan to fill the TV screen. Is this what I supposed to do or did I screw up somewhere?
Old January 21, 2014, 09:08 PM
Birk's Avatar
That is pretty standard, I even have to do that with my 27" with the 7970
LAPTOP HDMI TO LCD TV HDMI NOT WORKING appplejack Display Units 15 May 3, 2014 11:15 AM
Dvi to hdmi help jimmyb007 Peripherals 2 March 28, 2012 05:18 PM
VGA vs HDMI ecck Video Cards 9 January 16, 2012 10:39 AM
HDMI 1.3a or 1.4a? mo' power Audio 3 December 2, 2010 11:53 AM
HDMI>DVI-D? TheWanderer Display Units 3 May 1, 2010 09:53 PM
