Old January 19, 2014, 04:09 PM
sakage.shinga's Avatar
Default Turning my old build into HTPC
Hi guys,
Now that I have my new build, I'm going to turn my old one into a HTPC. I don't think I'll need to do any upgrades at all since it's still a pretty killer rig. The only thing that I might add to it is a SSD to help it boot up faster. Any recommendations? I'm currently looking at Samsung 840 EVO (120GB), Intel 530 series (120GB), and Kingston SSDNow V300 (256GB). I think 120GB will be enough since I'll have fewer apps installed on it after I've reformatted it (before format it's sitting at 87GB with Win 7, lots of apps including photoshop installed).
Aside from the SSD, is there any changes you guys would make? See my sig for old build system spec.
Thanks!
Photography/Gaming build: i7-4770K, NH-D14, Z87 Sabertooth, 16GB Ripjaws X, GTX 780 OC DirectCU II 3GB, M500 480GB, Caviar Black 2TB, Dual Red 4TBx2 (RAID 1), XFX Pro 850W 80+ Gold, Graphite Series 600T SE White
HTPC build: i5-750, Hyper 212+, P7P55D Pro, 8GB Ripjaws X, R6970 DirectCU II 2GB, Caviar Black 640GB/2TB, Caviar Green 3TB, Seagate Barracuda 3TB, Strider Plus 750W, CM 690 II Advanced
Mobile Media: Asus Transformer Infinity 32GB w/ keyboard dock
Old January 19, 2014, 04:14 PM
ZZLEE's Avatar
The Intel has the best reliability.
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old January 19, 2014, 04:18 PM
So in your opinion, is it worth it? My current 640GB Caviar Black can boot up pretty fast on a fresh install of windows and with only a few apps installed, I'd say between 50-80 seconds depending on how many apps I have. How much of an improvement can I expect if I just have Win 7, XBMC, MPC-HC, Office, Firefox and perhaps a couple others installed?
Old January 19, 2014, 04:31 PM
ZZLEE's Avatar
Going from any HD to an SSD is such a change.
Under 30 seconds from power on to to good to go in my experience.
Old January 19, 2014, 04:50 PM
Bond007's Avatar
The old computer is still very solid (if anything it might be overkill as an HTPC....unless you plan to do gaming on it as well). To add an SSD or not is really your call. Will the improved boot and application launch time affect any of your planned uses for it as an HTPC? If so and you have the money then go for it and add the SSD. If its only going to see basic use and/or money is a concern, then consider saving the cash.
Old January 19, 2014, 09:40 PM
Yeah that's pretty much my dilemma right now. The computer can still boot up pretty fast so long as I don't load a bunch of apps. The only problem right now is that I haven't nailed down exactly how many apps I will eventually load. Also I'm not very familiar with XBMC at the moment and on how much it would benefit from loading from a SSD.
Since the Intel is sort of on sale at the moment I might just grab one and test it out.
Old January 19, 2014, 10:56 PM
How often are you going to be booting this HTPC, that is the question.
If it's maybe once a day, I wouldn't bother. If it's a few times, then maybe.
For an HTPC build you'd be better off spending the money making it quieter, not faster.
Of course, an SSD would eliminate hard drive seek noise, so...
Old January 19, 2014, 11:00 PM
My current HTPC setup is i5 750, 8gb of ram, 80gb Intel SSD, 2 external usb drives hooked up to a 46" lcd tv through a Onkyo receiver with 2 Nuance Towers, 2 Nuance satellites, and a nuance center channel.
The HTPC has a blu-ray drive so I can watch movies if I want and runs Windows 7 using XBMC as players for media and PowerDVD for blu-rays.
Is it overpowered? Yup. Does it work? Very well.
Old January 20, 2014, 02:59 AM
I think I might go ahead and install a SSD. At the very least it'll make installing/updating Windows 7 a breeze. And who knows, if I can spare 60GB out of that 120, I may use it as a cache to speed up the Caviar Black 2TB I'm leaving in the build.
Old January 20, 2014, 06:24 AM
To be honest the 2 reasons I put a SSD into my system was for loading/boot times and quietness. Otherwise it wouldn't matter.
My first HTPC build Lalji New Builds 20 December 21, 2012 10:07 AM
New HTPC Build MorePower HTPC Systems & Software 17 November 5, 2012 05:37 PM
HTPC Build Dwayne New Builds 5 April 23, 2011 04:31 PM
HTPC build Kerry D HTPC Systems & Software 15 September 22, 2009 07:27 AM
New HTPC build FrankyG HTPC Systems & Software 3 December 4, 2008 06:02 AM
