Old January 20, 2014, 10:54 PM
sakage.shinga's Avatar
Well guys I've run into a bit of a problem. Just realized that my Asus Radeon HD 6970 DirectCU II 2GB does not have HDMI outputs! It has two DVI ports + FOUR display ports! Haha
So, keeping in mind that I will be connect the computer directly to my Sony receiver via a single HDMI cable (for both audio & video), should I get a HDMI/DP adapter, or simply get a video card that has HDMI outputs?
Priority for me is: image & audio quality, then quietness. Preferably the new card (if I get one) should be equal in performance to the 6970 I already have.
What do you guys think of the XFX Radeon HD 7850 Core Edition 860MHZ 2GB
Thanks!
Photography/Gaming build: i7-4770K, NH-D14, Z87 Sabertooth, 16GB Ripjaws X, GTX 780 OC DirectCU II 3GB, M500 480GB, Caviar Black 2TB, Dual Red 4TBx2 (RAID 1), XFX Pro 850W 80+ Gold, Graphite Series 600T SE White
HTPC build: i5-750, Hyper 212+, P7P55D Pro, 8GB Ripjaws X, R6970 DirectCU II 2GB, Caviar Black 640GB/2TB, Caviar Green 3TB, Seagate Barracuda 3TB, Strider Plus 750W, CM 690 II Advanced
Mobile Media: Asus Transformer Infinity 32GB w/ keyboard dock
Old January 21, 2014, 01:18 PM
SpaceSquad's Avatar
Originally Posted by sakage.shinga View Post
<snip>should I get a HDMI/DP adapter
Yes, save your money
-Space
Old March 23, 2014, 12:50 AM
Shadowarez's Avatar
Could look into the 750-Ti that just came out. New maxwell architecture and its lil potent beast for under $200. Im getting one to replace a nvidia 430gt lol the 750-Ti has lower power triple performance and double ram. So itll be nice for Transcoding streaming.
My first HTPC build Lalji New Builds 20 December 21, 2012 10:07 AM
New HTPC Build MorePower HTPC Systems & Software 17 November 5, 2012 05:37 PM
HTPC Build Dwayne New Builds 5 April 23, 2011 04:31 PM
HTPC build Kerry D HTPC Systems & Software 15 September 22, 2009 07:27 AM
New HTPC build FrankyG HTPC Systems & Software 3 December 4, 2008 06:02 AM
