Old January 17, 2014, 02:15 PM
great_big_abyss's Avatar
Default Intel HD4000 Graphics kinda suck for HTPC
I have an MSI Z77A-G45 and an I7 3770K using HD4000 IGP hooked up to a 720p samsung TV.
It defaults to 1024x768, and the next option is 1280x720. What I really need is 1280x768...but that option doesn't exist.
I dunno...it just seems like AMD's solution was much better suited to HTPC purposes than Intel's solution...
Any tips? Am I doing something wrong?
Old January 17, 2014, 03:13 PM
Dr_BenD_over's Avatar
Fallen Folder
What are you using for a connection? I found VGA was limited but using HDMI offered more options.
All's well that's Haswell
Old January 17, 2014, 03:16 PM
sswilson's Avatar
My HD 4000 allows me to select that res (just double checked on my Dell 1600 X 1050 ).
Did you go into the properties of the monitor and deselect the "hide modes that this monitor cannot display" checkbox? When I right click to change resolution the option you mentioned is there, but it's greyed out (assumedly because the monitor doesn't natively support it). Even though it's greyed out I can still select and apply it.
edit: This is with a VGA connection.
Size:  24.2 KB Name:  non Native Res.jpg
Old January 17, 2014, 03:28 PM
VGA is capable of 1080p but you should be using HDMI or DVI at the minimal.
So I am going to say that you are doing something wrong and or your TV doesn't properly support certain resolutions. Remember a 720p tv is only going to be able to do 1280x720.
Old January 17, 2014, 07:34 PM
i'm using hdmi
Old January 17, 2014, 07:43 PM
Originally Posted by great_big_abyss View Post
i'm using hdmi
Then you have a driver, cable, or tv problem.
Old January 17, 2014, 08:07 PM
Bond007's Avatar
Agree.
The i3 540 I installed years ago in a build for family and its integrated "HD" graphics runs 1080p (with options for all the other common settings). So I am sure your CPU and integrated can.
Old January 17, 2014, 08:17 PM
Fixed it...sort of. I had to select 1280x720, then manually adjust the aspect ratio vertically and horizontally, as the screen was initially bigger than the TV.
AMD's drivers sorted itself out all by themselves...just sayin'
Old January 17, 2014, 09:44 PM
KaptCrunch's Avatar
should check your firmware for the screen is up to date
Does Intel Quick Sync suck? Or is it something else? s_mack HTPC Systems & Software 9 August 16, 2012 03:44 PM
HTPC sub $400 FM1 chipset vs AM3 + Graphics Scotch Tape New Builds 3 September 26, 2011 04:55 PM
Intel HD Graphics with Graphics Card MoUnit CPU's and Motherboards 4 August 6, 2011 03:54 PM
What graphics card do I pick for my HTPC Blu Video Cards 7 December 31, 2010 12:12 AM
IS onboard UMA graphics any good for HTPC? Shadowmeph HTPC Systems & Software 8 July 27, 2009 09:44 PM
