Old January 15, 2014, 12:49 PM
Shadowmeph's Avatar
Default need suggestions for Mitx htpc build
I have been using an older pivos media player but it is getting really slow and the wifi drops , I have decided to look into a cheap Mitx build but not sure what to get, I used to just use an old PC but that takes up allot of room so the smaller the better
Old January 15, 2014, 01:40 PM
ZZLEE's Avatar
What you want
Drives 2,5 or 3.5 ?
5.25 ?
form factor m ITX
length of video card
RAD support ?
Edit : https://www.youtube.com/watch?v=FbhPMe7T27Y New Silverstone case.
Case determines allot of things in A m ITX Build
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old January 15, 2014, 02:06 PM
Shadowmeph's Avatar
Well the smaller the better and the case should be able to hold a standard PC harddrive
Old January 15, 2014, 02:28 PM
sswilson's Avatar
This is probably next on my list of cases I want to try out.....
Cooler Master: Elite 110
Old January 15, 2014, 02:31 PM
ZZLEE's Avatar
Look at this one
https://www.youtube.com/watch?v=lOGNUSvzjMI
small
The SSD hard drive combo from WD may be usefull to you.
Wanting to put in 3.5 Inch drives limits you. 1 hard drive or 1 optical drive is supported in this case.
I has space fore 2 x 2.5 also.
Needs short Video card and special size PSU.
[WTB] mITX Board/Processor/Ram for an HTPC m0pelley99 Buy/Sell & Trade 6 September 30, 2012 01:28 PM
High-end MITX Build Luay79 New Builds 9 September 19, 2012 07:01 PM
MITX Heavenly Build Luay79 New Builds 3 June 13, 2012 12:38 AM
HTPC Build Suggestions Pukka HTPC Systems & Software 1 March 2, 2011 09:05 PM
HTPC Build suggestions Shadowmeph HTPC Systems & Software 3 July 24, 2009 11:13 PM
