Old September 30, 2013, 06:58 PM
rfglass's Avatar
Default separate hdmi sound
I have a 775,core2 duo pc with a gfx card with HDMI that i have hooked up to my lcd TV, problem is my TV does not have left and right sound outputs. Next to running a pin to rca splitter to run sound to my reciever from the PC is there a way to separate the HDMI sound and send it to my reciever? From what i read that signal is/can be encrypted. Maybe a dongle or a inexpensive box that is hdmi compatible with rca outs?
Old September 30, 2013, 07:38 PM
Umm what?
Why not run the HDMI from the gfx card to the receiver and then run a hdmi from receiver to tv?
Your question is very hard to understand and try to figure out.
Old September 30, 2013, 08:32 PM
KaptCrunch's Avatar
SIMPLE if TV has earphone jack
Note set to low volume other wise you burn out speakers due to over modulation
Old September 30, 2013, 09:01 PM
rfglass's Avatar
Originally Posted by enaberif View Post
Umm what?
It's an older Nakamichi receiver and no HDMI inputs.. I just want to know if there is a way to sperate the audio from an hdmi cable into left and right rca jacks
Old September 30, 2013, 09:04 PM
rfglass's Avatar
Kaptcrunch will probably have to got your way.But run pin from pc-rca->receiver
Old September 30, 2013, 09:31 PM
KaptCrunch's Avatar
green 1/8 plug for line out
Old September 30, 2013, 09:52 PM
You get one of these:
http://www.ebay.com/itm/3-5mm-1-8-Y-...-/280800737440
Plug it into the onboard of your motherboard and run it straight into the receive.
Use the HDMI strictly for video to your tv.
Old October 1, 2013, 08:49 AM
rfglass's Avatar
Yup have a few of them. I guessing that separating audio from a HDMI cable is more of a hassle than it's worth. Did some googling on the idea and getting no definitive answers. The pc audio split to 2 rca I have known about for ever. So please stop posting that suggestion. But thanx for your input.
Old October 1, 2013, 09:31 AM
KaptCrunch's Avatar
back to OP, what your asking is not audio coming from PC but TV to amp/recvr looking for theater sound? dolby non stereo sound Coaxial Dolby AC3 DTS Digital
question what amp/recvr and model, also tv needs to support AC3 DTS Digital
Old October 1, 2013, 10:09 AM
TVs have never and still don't as far as I know decode ANY digital signal to something like AC3 or the likes. TVs do stereo and video only. Its the receive which does the decoding of the audio signal and only to speakers not to another device.
HDMI Sound Issue Dr_BenD_over Troubleshooting 7 October 7, 2013 11:40 AM
GTX 580 HDMI sound mardig88 Troubleshooting 9 January 20, 2012 08:36 AM
Sound via HDMI to TV Bond007 Troubleshooting 20 February 16, 2010 05:09 PM
HDMI and no sound Wurmer Troubleshooting 12 July 3, 2009 04:17 PM
No HDMI sound from my P5E-VM biff O/S's, Drivers & General Software 2 January 8, 2009 07:45 PM
