Old October 1, 2013, 10:09 AM
Shadowmeph's Avatar
the splitter is the only way plug HDMI into TV , then output TV ( head phone) to the splitter into the Amp unless of course the TV has rca or other type of output which some do have surround out the only way to know is to check out the brand of TV or look at the back of the TV or Monitor and see the Outputs.
oops I should correct myself I just rechecked the back of my TV and what I had thought where out puts where inputs
Old October 1, 2013, 10:20 AM
KaptCrunch's Avatar
ARC
Audio Return Channel is a feature built into the latest versions of HDMI (1.4, and presumably future versions). In its most basic description, ARC sends audio from the TV back down the HDMI cable to something like a soundbar, home theater in a box, and even a few A/V receivers.
yes TV needs OUTPUT of digital audio to amp that support dolby #11
notice #10 supports subwoofer
Old October 1, 2013, 10:59 AM
rfglass's Avatar
I'll probably need something like this to get away from the 1/8" pin to rca. I'll just keep it simple. Thanx all
http://www.octavainc.com/HDMI%20dist...02%20port.html
Old October 1, 2013, 11:55 AM
great_big_abyss's Avatar
That seems expensive for what you want to do.
What is wrong with running HDMI to your tv, and pin/RCA to your receiver? That's why I do on my HTPC, and it works fine!
Old October 1, 2013, 02:56 PM
rfglass's Avatar
That's what I'm going to do. Simple and cheap
Old October 1, 2013, 08:16 PM
KaptCrunch's Avatar
Old October 5, 2013, 02:44 PM
I'd be trying to run the audio directly to the receiver from the computer myself. There should be an audio output on the computer or sound card and an audio input on the receiver which runs all the channels after that. You can do it either RCA, HDMI or Optical typically. Optical doesn't support lossless audio though for Bluray so HDMI 1.4+ is always gonna be the best option. RCA jacks should support lossless audio too. It really depends on the receiver.
A decent receiver is an important aspect of running home entertainment IMO and rather than buy that piece of equipment you posted I'd invest that money into a receiver that has multiple HDMI inputs and one or 2 outputs to your TV/Display. These receivers typically have multiple audio input options to help you connect everything while providing the best audio for each of your devices.
Mah Rig now
Mah Rig before
My stuff for sale.
Old October 13, 2013, 05:33 AM
MARSTG's Avatar
Your receiver does not have Optical audio in?
HDMI Sound Issue Dr_BenD_over Troubleshooting 7 October 7, 2013 11:40 AM
GTX 580 HDMI sound mardig88 Troubleshooting 9 January 20, 2012 08:36 AM
Sound via HDMI to TV Bond007 Troubleshooting 20 February 16, 2010 05:09 PM
HDMI and no sound Wurmer Troubleshooting 12 July 3, 2009 04:17 PM
No HDMI sound from my P5E-VM biff O/S's, Drivers & General Software 2 January 8, 2009 07:45 PM
