Old September 1, 2013, 06:42 AM
Default netflix, vudu, cinema now?
Just got a smart tv and looking into these things. anyone use these, good or bad info, pain in the butt factor, costs?
Old September 1, 2013, 03:54 PM
FreeKnight's Avatar
I have Netflix and it's pretty meh. The selection is only ok (better if you have kids I suppose, but I don't), and they do keep a mix of old and new movies. For the 8 bucks a month (or something like that) and since I don't have cable, it does the job well enough, but if you're an avid TV watcher you might find it's not enough or that its too far behind on some shows (2-4 seasons behind), or that some of the blockbuster shows just don't end up on.
It's simple to use (browser based) and most consoles, media players and such all have netflix apps that work well enough. If you have a VPN or are familiar with them it's easy enough to change to the US/UK/CAN selection when you feel like it. I briefly looked into some of the other streaming services but the Canadian options are a lot more limited it seems. If you're in NC you can probably find a lot more easily.
Old September 1, 2013, 03:57 PM
supaflyx3's Avatar
To be honest, the smart TV implications I've seen are down right terrible. Both on LG and samsung TVs, they're slow as all hell and freeze often. It might be best to invest in a chromecast or something similar if you want to stream media to your tv.
Old September 1, 2013, 06:17 PM
anybody use roku or apple tv or any of those add on boxes?
i have thougth about making a HTPC and installing XBMC and trying to get things that way but not really sure how that works or what it does other than looking at the XBMC web site which only really confused me.
Old November 9, 2013, 07:51 AM
Netflix Canada just isn't as good as Netflix America
Netflix Canada: The Best Movies And TV You Only Get In America
Old January 8, 2014, 12:01 AM
Lima's Avatar
nice read
thanks
Old January 9, 2014, 08:52 AM
I have netflix. I also pay for this, adfreetime.com. It is 2 bucks a month, you add the DNS servers to your Router and every computer/device on your network thinks it is in the US, you get Netflix US on every device, works flawless and Netflix in the US is amazing.
Auzentech X-Plosion 7.1 Cinema card really quiet. Pine Troubleshooting 3 September 2, 2010 11:38 PM
[WTB] Dell 3007WFP-HC/Apple Cinema Display 30" Chilly Buy/Sell & Trade 4 April 22, 2010 06:15 PM
AuzenTech X-PLOSION Cinema 7.1 jay51 Audio 5 October 30, 2009 02:23 AM
Auzentech X-Plosion 7.1 Cinema hobbes666 Audio 5 January 15, 2009 02:37 PM
