Old August 12, 2013, 11:02 AM
Ravenor's Avatar
Default REMOTES THAT PEOPLE ARE USING FOR THEIR HTPC'S
Hey Everyone. I'm using a wireless mouse right now for my HTPC but I find it's not the greatest. Range from the box to the mouse is about 5.5 - 6 feet, mouse doesn't always seem to send the signal and always requires line of sight to work. Any Recommendations that keep the price under $50 for a decent remote. I want something that can RMB and LMB click and scroll up and down and have decent range.
Roy: [singing] We don't need no education.
Moss: Yes you do; you've just used a double negative
Old August 12, 2013, 11:10 AM
sswilson's Avatar
Does it have to be a remote? I'm a big fan of the Logitech K400 wireless keyboard / touchpad unit.
Logitech K400 Wireless Touch Keyboard With Built-in Multi-Touch TouchPad Black
Old August 12, 2013, 11:11 AM
supaflyx3's Avatar
I use my phone, best remote you can possibly use, other than maybe a tablet.
Old August 12, 2013, 11:17 AM
Supergrover's Avatar
Yup same,While I have a few Harmony remotes (880/One/Touch) connecting VIA my Tuners IR. I find myself picking up my Tablet more often than not when I want to do something more than play/pause/stop.
R.I.P.
Old August 12, 2013, 11:42 AM
supaflyx3's Avatar
Yatse for XBMC
Unified Remote for everything else
Old August 12, 2013, 12:19 PM
Shadowmeph's Avatar
obviously you would need some type of receiver to receive the signals from your tablet or phone where do you find such type receivers?
Old August 12, 2013, 12:25 PM
No receiver needed it is normally done via a server client installed on the HTPC, some are native, I know my PB app for WMC needs no server client software it just works but thats WMC only.
EDIT: Just to clear things up Shadow it uses your wireless network to send the signal from your tablet/phone to the HTPC.
R.I.P.
Old August 12, 2013, 12:40 PM
The Logitech K400 is the best thing ever for HTPC. Furthermore, it's a universal USB device, meaning you can use it with whatever supports the universal USB protocol. I've used it on Xbox 360, PS3, WDTV, my smart TV capable Panasonic plasma, etc.
Old August 12, 2013, 01:05 PM
I have not used the K400 but I do own a couple wireless HTPC keyboards, 1 trackball, 1 touchpad. The problem I find with them if you are looking for a remote is simply the size, sure you can type on them but how often are you needing to use a fullsized ( or slightly smaller KB footprint) on a HTPC? I know for how I have mine setup I hardly have to use more than 1-2 keys before autosearch brings up what I am looking for mediawise.
IMO, again IMO, if you are going to use a keyboard with a HTPC then yes something like the K400 would work but if all you are going to use the HTPC for is well HTPC support then someform of a remote works better.
Sadly OP it has been years (XP days) since I bought just a remote and usb/IR and thats getting pretty dated nowadays.
R.I.P.
Old August 12, 2013, 01:50 PM
lowfat's Avatar
I'd rather use a keyboard/mouse combo than a remote. Especially if you are using something like XBMC and have a large library. Unfortunately there aren't any good ones. I've tried pretty much every micro keyboard/trackpad combo and they all aren't very good. I now use a K400 and it is tolerable but so big and bulky.
I've tried pretty much all the Android or iOS tablet apps and IMO they aren't all that great either.
Mael
Big Lian Li
Forever Alone
Have people here ever used UDK? ShinraCorp Gaming 0 February 14, 2013 06:17 PM
Why do people put........ crazyea Off Topic 35 July 18, 2012 08:38 AM
People from MTL I need your help FlyingFish Off Topic 12 July 30, 2011 11:15 AM
What's with you people? Squeetard Off Topic 38 October 15, 2009 05:00 AM
Samsung Remotes - Q element291 Display Units 0 July 9, 2009 02:25 PM
