  #31 (permalink)
Old November 25, 2013, 12:21 PM
lowfat's Avatar
For an HTPC I find the K400 too big. I really find myself missing one of my old smaller keyboards. But I've never had any issues w/ connection. I am rather disappointed it doesn't work w/ Setpoint. It isn't possible to change what the media keys open.
Mael
Big Lian Li
Forever Alone
  #32 (permalink)
Old November 25, 2013, 12:23 PM
SugarJ's Avatar
Thanks Inik, 5 meters would be about the farthest it would have to work and most seating positions would be 3-4 meters in my TV room.
EDIT: And thanks lowfat, too. It would mostly be for backup use, in case I have to use a keyboard for something. The idea is to use a 360 controller mostly.
  #33 (permalink)
This is what I'm using:
Lenovo Multimedia Remote Keyboard N5902 (Non-backlit) | Lenovo | (US)
Depending on usage can go through a lot of AA batteries. Has no function keys if you need those. Range is good.
  #34 (permalink)
Old November 25, 2013, 12:38 PM
lowfat's Avatar
Do you know if this works w/ XBMC? I've tried a Logitech one and it unfortunately did not work.
Mael
Big Lian Li
Forever Alone
  #35 (permalink)
Old November 25, 2013, 12:56 PM
Arinoth's Avatar
I just use the XBMC app on my smart phone or tablet once my XBMC has been configured with a wired keyboard/mouse.
Here I am: here I remain
  #36 (permalink)
Old November 25, 2013, 01:03 PM
LionRed's Avatar
For years I have been using SnapStreams FireFly PC Remote SnapStream Firefly: Overview
2 main reason I like it....
It uses radio frequency (RF) and no input lag at all. The main thing about it being an RF remote, I have a plasma tv...seems plasma tv's can interfere with ir devices (lotta hair pulling before FireFly).
The buttons can be edited on the FireFly to run a program. For example starts up XBMC and it can exit the program with one button.
Should point out ...once properly setup to use with XBMC.....it works flawlessly in XBMC.
They say you can tell how rich a man's life has been, by how many dogs he has had in it.
RIP Kiwi - Oct 19th/05 - April 18th/11, you will always be our puppy!
  #37 (permalink)
Old November 25, 2013, 01:04 PM
SugarJ's Avatar
I have not run XBMC so I can't tell you. I'm waiting on Steam OS and the idea is to stream content and Windows only games from my main PC. It may run Ubuntu for media and iRacing until then, or dual boot.
  #38 (permalink)
Old November 25, 2013, 02:06 PM
sswilson's Avatar
How are you finding the K400? Range ok? I was looking at that for my Steam Box clone.
Originally Posted by Inik View Post
I have a K400 also in the living room attached to my HTPC. No problems at 4-5 meters. I did not really tried further than that.
EDIT : I had to change the battery once in 8 months of usage.
I haven't pushed it any further than that, and have always ensured a line of sight, but 10 - 15' seems to be fine.
  #39 (permalink)
Old November 25, 2013, 02:16 PM
LionRed's Avatar
Just for fun I decided to see how far this FF remote goes....
Walked down to the garage (roughly about 75 feet), through 4 walls and it still works...gotta love RF.
  #40 (permalink)
Old November 25, 2013, 08:29 PM
Shadowmeph's Avatar
Originally Posted by supaflyx3 View Post
Yes you can, check out the link i posted for yatse on the previous page.
I wished thaat this worked for my laptop lol
Have people here ever used UDK? ShinraCorp Gaming 0 February 14, 2013 06:17 PM
Why do people put........ crazyea Off Topic 35 July 18, 2012 08:38 AM
People from MTL I need your help FlyingFish Off Topic 12 July 30, 2011 11:15 AM
What's with you people? Squeetard Off Topic 38 October 15, 2009 05:00 AM
Samsung Remotes - Q element291 Display Units 0 July 9, 2009 02:25 PM
