Old July 1, 2013, 07:40 PM
Prolab's Avatar
Default Old server -> HTPC w/ XMBC front
Hey guys,
Im planning to redo my server (see sig) and the old one will be assigned to be a HTPC w/a XBMC front.
CPU + Mobo, 2GB of RAM will be used and a small HD running Win 7 + XBMC. Is my MOBO good enough to play 1080p content? Or do i need to add a GPU?
What GPU you guys recommend? No gaming on this HTPC. Strictly 1080p playback and general web browsing.
Gaming Rig:
-Caselab STH10, Swiffy MCP35x2, (2) Aphacool UT60 480 rad, HWL GTX 360, Heatkiller IV, i7 5930k @ 4.5 Ghz, 16GB Ripjaws, Asus X99 Deluxe ii, (2) XFX R9 290 w/ XPSC WB, 240 GB Intel 530, 500 GB 850 EVO, (6) 3 TB Tosh HD, EVGA G2 1300 PSU, Win 10 Pro
HTPC Rig:
-G3258 @ 4.0 Ghz, Asrock Z97 Pro 4, Asus 290, 128 GB Crucial M4, (2) 2 TB WD Green, (1) 2 TB Sammy F4, (2) 5 TB Tosh HD, Enthoo Primo, XSPC 480, 240 HWL GTS, Corsair HX620, Win 10 Pro
Old July 1, 2013, 08:00 PM
lowfat's Avatar
This would be a good choice. Although I am doubting the fan choice.
Gigabyte Radeon HD 6450 625MHZ 1GB 1.1GHZ DDR3 Low Profile DVI HDMI HDCP PCI-E DX 11 Video Card
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old July 1, 2013, 09:57 PM
Prolab's Avatar
Cool, thanks man. Hopefully this would work with my Onkyo receiver.
Gaming Rig:
HTPC Rig:
Old July 1, 2013, 09:59 PM
i am using a nvidia gt520 silent and have no issues
Old July 2, 2013, 05:31 AM
SpaceSquad's Avatar
I have a 5450 that I picked up for pretty cheap. Works great with anything I throw at it. Specs are somewhat similar...Pentium D, 2GB, and an older mechanical HDD.
-Space
Old July 2, 2013, 07:11 PM
Prolab's Avatar
Okay thanks for the feedback
Gaming Rig:
HTPC Rig:
Old July 2, 2013, 07:15 PM
i just upgraded my media center from an athlon x2 5050e 2.6ghz, 4gb ram, and a geforce 610 which was previously a radeon 4250.
HD was no issue, however, if you plan on using any plugin's i've noticed that if you leave it running long enough, xbmc's memory usage alone would get close to 2gb as some plugins seem to be a little buggy, so if you could get it up to 4gb, it might keep things running smooth so it doesn't start relying on page file
also, if you're planning on using the live tv with a tv server on the same system, more ram will help
just so you know, the only reason I upgraded was so I could play some games here and there, so i jumped up to a new A10-6700 APU. I figured the dual core with 4gb was pretty taxed, so a quad core with 8gb and integrated graphics should add enough extra resources to do so
bottom line is, any videocard will do for HD playback now days, ram should be your concern if you ask me
if it's going to be solely a media center, you might also consider running xbmc as the shell, skip the windows desktop entirely. If you really wanted too, you could use rt7lite to strip windows 7 right down to the bare minimum like i did.
Old July 3, 2013, 06:18 PM
Prolab's Avatar
Sounds like a better idea compared to what im planning. Im limited to 2GB DDR2 since that was the only amount i purchased because of WHS v.1 RAM limitations.
I dont have any plans to use live TV as i have basic cable for that. Primarily this HTPC will be playing all the movies/TV shows i have from the server and browsing the web instead of firing up the gaming PC.
Gaming Rig:
HTPC Rig:
Old July 3, 2013, 09:52 PM
hmmmm,
web browsing might potentially pooch the idea of running xbmc as the shell, unless you use the advance launcher plugin to run IE, chrome, firefox, what have you. or there might also be a decent web browser plugin/wrapper for xbmc
if you're not planning on using live tv in xbmc, you can maybe get away with 2gb ram pretty well since there's no need to enable a pvr addon, or run a tv server in the background. I personally would still be more comfortable.
not to sound like i'm soliciting here though, lol, but pm me if your interested, i may be willing to let my geforce 610 go for cheap, i think i even have some ddr2 around, might be able to help out. I can help out with some tweaking to the OS install, branding, etc as well. I've been getting lots of practice with xbmc htpc setups lately, and setting up ir remotes, ughr...
htpc server questions dinmaster HTPC Systems & Software 2 May 24, 2011 01:53 PM
WIP HTPC(XBMC)/Server Rig Arinoth Case Mods, Worklog & Gallery 34 September 24, 2010 11:40 AM
HTPC/Server Build Arinoth New Builds 23 July 2, 2010 08:15 AM
htpc media server 99tjadams New Builds 4 November 5, 2009 07:55 PM
Need help with HTPC/Server ben_the_nerd HTPC Systems & Software 10 October 16, 2009 09:37 AM
