Operating System My HTPC was on hold for a few months but I'm about to start putting it all together. I was planning on buying a fresh copy of Window 7 for the system but I'm not sure what version I should be getting? Home Premium, Professional or Ultimate?:doh: Does it even matter? Or how about Windows 8? :ban: I will be running XBMC as my main hub. Any thoughts on the subject would be greatly appreciated! |
myself if I was going to just be using it for XBMC then I would install a free OS like Linux and then run XBMC or even xbmcbuntu-12.00.Intel-AMD but that is just me. |
I'm running Windows 8 with xbmc and it runs just fine, though I'm not 100% sure if it's Win 8, xbmc or what have you but whenever I boot mine up,it never goes to the native 1080p resolution, normally a lot lower. So I have to close and re-launch it, don't remember it ever happening in Win 7. If you can use Win 7 over Win 8 I'd still recommend doing so. |
I personally like windows 8, the tiles would look pretty sweet on a tv as well. |
I've been using windows 7 Pro on my current PC & have no complaints. I am not that tech savvy so Linux and Ubuntu are sort of out of the question. Windows 8 is sort of a wild card for me still as far as compatibility issues with XBMC as posted by Arinoth. I'm looking at Ubuntu and I like what I see.. Thanks Shadowmeph! This looks like an option I hadn't thought of. |
I have Ubuntu + XBMC installed. Crazy fast boot-ups on some older hardware. Plays back video perfectly, nice web browsing, I am very pleased. Specs: Pentium D 3.4 2 GB DDR2 5450 1GB Sata HDDs Wifi (bad location for wires) Ubuntu 12.10 Search dx.com for cheap handheld wireless keyboards - I bought my rechargeable one for 20 bucks and am very happy with it. EDIT/ All I have to do configuration-wise was enable proprietary AMD graphics drivers. This is so easy to do - it's under Ubuntu Software Centre > Edit > Software Sources > Drivers. Wifi and everything worked out-of box - I just wanted 3d acceleration via radeon drivers. |
If all you plan to run is XBMC and never leave it, I'd say install XBMCbuntu (Index of /releases/XBMCbuntu). All pre-configured and ready to go, very simple to install. Just burn to a disc, boot, click next a bunch of times, and your done. I personally found XBMC ran better that way rather than from Windows. Seemed much smoother and less glitchy/buggy. I surely wouldn't buy Windows with the intent of running XBMC on top. That's just a waste of money. |
I never heard of problems playing bluerays in Linux why would that be a problem? |
| All times are GMT -7. The time now is 04:29 AM. |
