Old February 25, 2013, 07:21 PM
It could possibly be the powerline ethernet adapters causing the lag. I've heard(I think from Greg at NCIX) that they don't play nice with some power bars/surge protectors out there. I seem to be lucky with my set as I use them too. Might be something to try eliminating if the above doesn't net any results.
Old February 25, 2013, 11:30 PM
It was the interlace video settings which only seem available when playing a video, they were off I set them to Auto mode and this resolved the issue, files play fine now over the network.
Did you try turning it off and on again?
Old February 26, 2013, 06:08 AM
Nice. Glad to hear its resolved!
Have you had a chance to try anything on Netflix in full 1080p HD? Thats what I need to find out about before I pull the trigger and get this setup myself.
Old February 26, 2013, 12:44 PM
I will test it out tonight and let you know.
Old February 26, 2013, 11:49 PM
I tested HD Netflix and had no issues at all streaming 1080p movies, it looks great on my new projector too.
Old February 27, 2013, 06:07 AM
Sweet. Come on tax return. Daddy needs a new HTPC....
New budget HTPC Build/ inputs appreciated rugox New Builds 0 March 11, 2012 04:15 PM
HTPC Build on a Budget (cont) BrooklynJew New Builds 4 September 13, 2011 03:24 AM
HTPC Build on a Budget BrooklynJew HTPC Systems & Software 3 September 12, 2011 01:49 PM
Budget HTPC/Gaming Build lcdguy New Builds 13 September 1, 2011 09:58 AM
Budget HTPC Build Dark-Colonel HTPC Systems & Software 4 June 29, 2011 07:50 AM
