  #31 (permalink)
Old December 18, 2012, 10:59 AM
Supergrover's Avatar
Originally Posted by sswilson View Post
I'd think ideally that you'd want to be able to access a win8 htpc (I'm thinking windows because of tuner support) using an android tablet based solely on power consumption. That'd be pretty kickass though, you wouldn't need heavy processing power because you're not looking to stream to the tablet, just have a display that allows touchscreen/mouse access.
No need of Win8 TBH, I scrapped my KB/Mouse connections to all my HTPC's, mind you 2 have remotes but I use a RDC or a simple media remote via the tablets. I have to say I have not looked back.
R.I.P.
  #32 (permalink)
Old December 18, 2012, 11:01 AM
sswilson's Avatar
Does your HTPC include a tuner or is it just (as is the case with most folks) downloaded/ripped content? Drivers for the tuner would be my main concern.
  #33 (permalink)
Old December 18, 2012, 11:10 AM
Yup all three have analog tuners, all under Win7. They handle the analog content and my PVR handles the HD. Only one is setup to stream TV to my tablet though.
But the tablets handle the remote functions as well as RDC when needed.
R.I.P.
  #34 (permalink)
Old December 18, 2012, 11:31 AM
sswilson's Avatar
Ok, so win7 vice win8 (I thought you were suggesting doing away with windows all together). I was thinking win8 just because it is a better touch interface so thought a tablet would more easily navigate the win8 start screen.
  #35 (permalink)
Old December 18, 2012, 11:49 AM
Heh I wondered what you were getting at.
Yes Win7.
While slightly different I am assuming that John will be using this for a mediacenter, music/movies/radio so not much different than a HTPC as stated.
And for this Win8 touch screen isnt a huge issue, 90% of the time your going to be working from a mediacenter, I find WMC with mediabrowser works just fine for anything I throw it's way, for working from within WMC I use either a remote. Or one of my tablets running a WMC remote app.
Now while in desktop mode persay, I use a RDC app to connect to the HTPC's and that has touch gestures built in.
So all I was saying is that Win8 isnt "needed" for the touch support, it works seamlessly under Win7 using the correct apps.
R.I.P.
  #36 (permalink)
Old December 18, 2012, 03:16 PM
3.0charlie's Avatar
Those were my taughts too: Win8 on the trailer-puter, add a router to create a network, and use the tablet with TeamViewer to log into the Win8 HTPC. This simplifies the whole deal too, since I don't need BT nor wireless to be inbedded in the motherboard - any mitx board with a single PCI-E 1x slot would do.
Kev, thanks for your thoughts and knowledge regarding this, it seals the deal quite well. Time to search into a board repalcement for the Zotac model, and order everything. This is going to be great!
Originally Posted by odis172 View Post
Are you still looking for an amp? I'm using this with a 3.5mm output from a tablet to my 4 car speakers. It works great. The on/off of the amp is controlled by the blue wire, so hook that up to the 12v of the psu for power control.
Alpine Electronics of America, Inc.
I did find one (https://www.springwateraudio.com/sto...products_id=51), but I didn't know Alpine made such small amps. Good to know if the selected model isn't up to par.
  #37 (permalink)
Old December 18, 2012, 04:41 PM
3.0charlie's Avatar
So, the final tally:
Board: Newegg.ca - Foxconn H67S LGA 1155 Intel H67 HDMI SATA 6Gb/s Mini ITX Intel Motherboard
Chip: Newegg.ca - Intel Celeron G550 Sandy Bridge 2.6GHz LGA 1155 65W Dual-Core Desktop Processor Intel HD Graphics BX80623G550
Case: Newegg.ca - APEX MI-008 Black Steel Mini-ITX Tower Computer Case 250W Power Supply
Tuner: Newegg.ca - Hauppauge WinTV-HVR 1850 MC-Kit FM radio and MCE remote PCI-E x1
Ram: whatever I have on hand, which is way too much.
DVD: Newegg.ca - LG 24X DVD Burner - Bare Drive 24X DVD+R 8X DVD+RW 8X DVD+R DL 24X DVD-R 6X DVD-RW 16X DVD-ROM 48X CD-R 24X CD-RW 48X CD-ROM Black SATA Model GH24NS95 - CD / DVD Burners
Router: Newegg.ca - NETGEAR WNR2000-100NAS Wireless-N Router IEEE 802.11b/g, IEEE 802.11n Draft 2.0
Amp: https://www.springwateraudio.com/sto...products_id=51
Total: 516$ shipped. Not bad. I have Win8 from my Technet account. That should cover everything.
edit: oh well, already found cheaper case, router, DVD-ROM...
  #38 (permalink)
Old December 18, 2012, 06:00 PM
sswilson's Avatar
Did you sign up for the free win8 media center key? If not, I believe the promo is still open until the new year.
  #39 (permalink)
Old December 18, 2012, 07:42 PM
3.0charlie's Avatar
Thanks to you, I just did. ;-)
  #40 (permalink)
Old December 21, 2012, 07:03 PM
3.0charlie's Avatar
Quick update: parts have been received and assembled; Windows 8 installed and updated with MCE - thanks Steve! (damn, UEFI install + Intel SSD = 8 seconds to desktop!). Using Splashtop (Best Remote Desktop App | Access Computer from iPad | Splashtop), I can connect wirelessly to the computer with my Acer tablet and the router I bought (using WAN only, with a dedicated/protected SSID). But Damn! I think the Hauppage Tv Tuner is busted since Windows does not recognize it - I mean, it won't even launch the New hardware window upon installation, nor does Device Manager sees it.
It's that or a blown PCI-E slot. I'll test some more tomorrow with a USB PCI-E card. Otherwise, everything works as expected.
Need help building a HTPC for a 47" TV kuro89 HTPC Systems & Software 11 July 12, 2012 12:04 PM
Have case,won't travel ! STEVE-5 New Builds 9 April 14, 2012 06:49 PM
Air Canada travel help Lpfan4ever Off Topic 6 December 29, 2011 08:14 AM
Building an HTPC - Critique my build! Andy New Builds 16 September 9, 2009 07:40 AM
Question for those who travel to Montreal. Droc Off Topic 4 January 23, 2008 04:54 PM
