Old December 17, 2012, 09:59 AM
3.0charlie's Avatar
I wished JD, I actually have a Pioneer AVIC-F900BT on my desk available; but it does not offer (like all car radios) a HDMI output for the DVD: the only video output is a composite Out.
Thanks Steve for more options, I'll dig into those also.
Hydro-Quebec is salivating...
Old December 17, 2012, 10:58 AM
sswilson's Avatar
I know I can use car amps, but using figuring out the remote power On for the amp is going to be an issue without a car radio. I'm trying to find an amp with no volume control since I want the trailer-puter to handle that. I also know I can connect a 1/8" jack / LR RCA cable to an amplifier from the onboard sound card.
Just need to find that amp! No worries about the existing amplifier (18w per canal), and the existing 6.5" speakers will be replaced anyway.
As per the scythe unit that runs off of 12V (the NCIX model actually has a molex connector for power) any of the small 12V amps like this one ( Amazon.com: Lepai TRIPATH TA2020 Class T Mini Amp Hi-Fi Stereo Audio Amplifier: Electronics ) could be powered by a molex connector and thus would be powered on by the PC power supply whenever you turned on the htpc. If you had the room you could even mount one to the outside of your HTPC case to address possible internal heat issues, all you would need would be to run a power connector from an internal 12V molex to the power input of the mini amp.
Old December 17, 2012, 11:24 AM
Arinoth's Avatar
AVerMedia AVerTV Global - TV Tuners, Live IPTV Streaming Encoder, Video Capture Card, Media Player and Multimedia Products - AVer3D CaptureHD may solve all your problems as it accept HDMI in as well as everything else that you want.
With some of the cards that do FM or OTA TV you may have to get a manual switch between the two as I believe the one I linked only has one connection. Though how hard would it be to add in a source switch for those two?
Here I am: here I remain
Old December 17, 2012, 04:38 PM
3.0charlie's Avatar
I like this - powered straight from the PSU. Great!
I've read the description a few times, and aside from the 3D aspect I don;t see what's different with the other cards?
Old December 17, 2012, 04:46 PM
Arinoth's Avatar
Nothing really, just that it supports FM/OTA TV, as well as HDMI in. Most of the cards don't have both of them together
Old December 17, 2012, 05:45 PM
3.0charlie's Avatar
k, tx. Digging through countless websites I stumbled upon this model, which fits my needs too: OTA (analog + digital) and on-air FM: Hauppauge Computer Works : WinTV-HVR-1850
It's available at the egg too.
Tx all. I think I have all I need.
Old December 17, 2012, 05:48 PM
Arinoth's Avatar
Only downside to that is you don't have your HDMI in that AverMedia has with their models.
Old December 17, 2012, 05:54 PM
sswilson's Avatar
Certainly pricier than what showed up at the US Amazon website, but this site (link from Amazon) has several different T class amps and is Canadian.
https://www.springwateraudio.com/sto...9f73f285742eee
edit: so what did you decide on for an amp?
  #19 (permalink)
Old December 17, 2012, 06:08 PM
3.0charlie's Avatar
I'm sorry - I meant HDMI output from a GPU to the 27" LCD. The board I found (Newegg.ca - ZOTAC D2700ITXS-A-E Intel Atom D2700 (2.13 GHz, Dual Core) Intel NM10 Mini ITX Motherboard/CPU/VGA Combo) has everything I need: HDMI, Wireless N, BT and an msata port for a no-cables setup.
Woah, great site! I'll dig in there. I taught about buying the Scythe for the PP price, but now I'm not sure... tx again!
  #20 (permalink)
Old December 17, 2012, 06:16 PM
3.0charlie's Avatar
Thanks Steve, I've found my amp! Not as cheap as the other models but being a Class D power and quality should be there: https://www.springwateraudio.com/sto...9f73f285742eee
Need help building a HTPC for a 47" TV kuro89 HTPC Systems & Software 11 July 12, 2012 12:04 PM
Have case,won't travel ! STEVE-5 New Builds 9 April 14, 2012 06:49 PM
Air Canada travel help Lpfan4ever Off Topic 6 December 29, 2011 09:14 AM
Building an HTPC - Critique my build! Andy New Builds 16 September 9, 2009 07:40 AM
Question for those who travel to Montreal. Droc Off Topic 4 January 23, 2008 05:54 PM
