Old November 23, 2012, 07:21 PM
cyberspyder's Avatar
Default Streacom Passive HTPC Build
Case - Streacom FC5-OD
Mobo - Gigabyte G1 Sniper M3 (got a pretty good deal on it, needed the features over power savings)
Proc - i3 3225 (mainly because of the HD4000 graphics)
Ram - 8GB Samsung Low Voltage
Storage - Intel 330 Series 120GB SSD
PSU - Standard 150W PicoPSU
Blu-Ray Burner - Panasonic UJ235A
PicoPSU and the AC/DC converter.
Thiiiiiiiick front panel.
Parts (aside from the Blu-Ray burner which is on a ship heading here from China).
Mock fitting.
Lapped all the thermal coupling blocks flat (I know, it's not a mirror finish, went up to 2000 grit).
Installed! Arguably the hardest part of the build, used up my entire tube of IC Diamond. Had to scrounge up some Arctic Silver to complete the jobby, no clue why Streacom did not include any thermal paste...
Power and SATA3 cables in place for future 3.5" hard drive expansion. Still waiting on the slim SATA adapter cable to plug the Blu-Ray burner in, allocated a molex connector on the bottom right.
3.5" hard drive mocked in place.
Now for the stress testing portions, sure an i3 doesn't put out that much heat, but the heatsinks still got plenty hot. Ran Prime95 + MSE full antivirus scan for a day just to be safe (partially because I wanted to cure the thermal paste) and found that the temps maxed out at around 70C, which is impressive for a completely fanless case.
Not bad for a consumer SSD.
Some of my opinions after buttoning up the system:
PROS
+Looks amazing
+Passive cooling system works pretty well
+Can fit a surprisingly amount of hardware inside
+Solid construction
MINUSES
-Too many parts make up the case, introduces flex because there are a lot of screw joints, would be better if the sinks were one piece
-Top and bottom panels could be thicker
-Finish could be better, but I understand the 'EVO' edition fixes this
-Cost!
-Unused heatsinks on the left of the case, would be better of the heatpipes were split between the two banks of heatsinks
So far I'm quite satisfied with the system. The SSD definitely speed things up a lot. My boot times were in the 15 second range with the standard installation of Windows 7 before any optimization. It has obviously slowed down a tad bit due to the programs I installed. The HD4000 graphics are amazing and effortless, I do not understand why anyone would pay for a more expensive i5 for HTPC duties (or even i7's) - the i3 is PLENTY.
HOWEVER, the best part of it all? 100% WAF AND its absolutely SILENT.
Brendan
Old November 23, 2012, 09:08 PM
lowfat's Avatar
That case is gorgeous.
Old November 24, 2012, 05:00 AM
Probably the nicest looking HTPC I've ever seen. Very sleek.
I like the idea alot but I don't understand why absolute silence is necessary in an HTPC. I can understand wanting to stop as much noise as possible but a small fan or 2 of good quality is next to silent if you're more than 3 feet away. I couldn't see myself spending extra cash just to make something I find inaudible completely silent. If I can't hear it from 3ft away thats good enough for me but thats just my opinion.
Old November 24, 2012, 06:57 AM
Arinoth's Avatar
That case is gorgeous and that's quite the low temperatures for full load situations.
Old November 26, 2012, 02:04 PM
Question Discrete GPU
Excellent build!
Will it be possible to employ a discrete Fanless GPU, for example, Sapphire ATI HD7750 Ultimate or AMD Radeon™ HD 6850, with this case?
Old November 29, 2012, 05:01 PM
Originally Posted by SoundSparks View Post
Excellent build!
Passive GPU's rely on airflow within the case to cool them. This case uses itself as a huge heatsink and relies on the minor airflow in the room to keep the processor cool. If you put a GPU inside of this case it will probably overheat because there is absolutely no airflow.
Old November 29, 2012, 05:12 PM
wirerogue's Avatar
neato!!!
Old November 29, 2012, 07:11 PM
WhippWhapp's Avatar
Humina, humina!
I rub and whack and choke and stroke!
Old November 29, 2012, 07:44 PM
sswilson's Avatar
Wow!!!! Great build, thanks for sharing, I wasn't aware of those cases at all!
Have you set something up to monitor the HDD temps? It's been quite a while since I heard of anybody having problems with an overheating HDD, but since there is zero airflow I'd be keeping an eye on it just in case.
Did you feel the case under full load? Is it sitting at around 70c?
Old December 3, 2012, 05:10 PM
Trial Member
Where did you buy your Streacom case?
New HTPC Build MorePower HTPC Systems & Software 17 November 5, 2012 04:37 PM
How not to build an HTPC Xeven HTPC Systems & Software 43 February 3, 2011 05:39 PM
My first HTPC Build demarderozan HTPC Systems & Software 2 February 24, 2010 10:19 AM
HTPC build help? 3.0charlie HTPC Systems & Software 11 October 4, 2008 02:14 PM
Yet another HTPC build- help? misterd HTPC Systems & Software 4 August 1, 2008 10:10 AM
