Old November 18, 2012, 06:59 PM
TheGomdoRi's Avatar
Default Stumped - Would really appreciate help with remote/IR
Objective: I am trying to use: Apple Remote - Wikipedia, the free encyclopedia with my PC to control foobar.
Why: I like the simplicity of the remote and feel/construction and I don't want a huge remote just for basic music control.
What I've found out thus far: The remote uses " NEC IR protocol[1] which consists of a differential PPM encoding on a 1:3 duty cycle 38kHz 950 nm infrared carrier."
- I'm going to need (1) remote (2) receiver - USB Internal Infrared (IR) Receiver Only with Cable and Mounting Bracket (3) software ??
STUMPED: Here is where I am having trouble... I am not sure which software I should be using to bind IR signals to commands for Windows 7.
The IR receiver does flash red when the remote is clicked but I tinkered around with EventGhost but failed miserably.
Any advice/tips/solutions will be greatly appreciated.
Old November 18, 2012, 07:08 PM
supaflyx3's Avatar
This might be of help: Using the Apple remote with a PC. « Uroscion’s Weblog
What errors are you getting with EventGhost?
BFBC2 issue hardware software I am stumped Painbringer71 Troubleshooting 11 September 1, 2011 05:18 PM
Dummy Needs Help Installing XP; Really Stumped... Dave Simpson O/S's, Drivers & General Software 9 October 3, 2010 04:04 PM
Netbook as remote? Cypher^64 HTPC Systems & Software 6 August 25, 2009 04:37 PM
I need a remote control TimTheEnchanter Peripherals 2 May 18, 2009 11:47 AM
[WTB] tv tuner with remote werth Buy/Sell & Trade 3 January 10, 2009 04:08 AM
