-   HTPC Systems & Software (http://www.hardwarecanucks.com/forum/htpc-systems-software/)
-   -   LF the smallest. sleekest ATX case! (http://www.hardwarecanucks.com/forum/htpc-systems-software/54128-lf-smallest-sleekest-atx-case.html)
DU5KIE May 10, 2012 04:48 AM
Looking for the smallest. sleekest ATX case for a HTPC out there! Preferably black. GO!
Jebusman May 10, 2012 05:06 AM
What exactly are you putting in it? They can get pretty small depending on what you're throwing in there.
sswilson May 10, 2012 05:46 AM
Why ATX vice mATX for an HTPC? That's going to make a huge difference in what cases are available, and the extra features on most ATX motherboards can be found on the Gene series of motherboards if you really need them.
Dr_BenD_over May 10, 2012 06:11 AM
Silverstone LC19 if you go down to at least M-ATX...
