Old February 16, 2012, 12:27 PM
486's Avatar
486 486 is offline
Default Smallest mATX case recommendation for HTPC
I have got Grandia 5. Way too big, regular size ATX PSU.
I would like to reuse my motherboard, and it is mATX. What would be the smallest black mATX case with industrial design (preferably) and picoATX PSU?
Silverstone TJ-08E
Seasonic X-660
Asus P8Z77-M Pro
Intel i7-3770
Kingstone HyperX 2 x 8GB
Crucial M4 256GB + 128 GB
Sapphire Radeon HD7970
Nec Multisync LCD2690WUXI
Old February 17, 2012, 03:40 AM
CroSsFiRe2009's Avatar
Other than a Sugo SG04/3. I can't think of anything that specifically fits matx and is industrial. Depending on your motherboard, you might be able to get away with a Lian Li Q11 if the mobo isn't too deep. Cooler Master Elite 360 or 361 when it gets released is also an option.
If you don't care for expansion cards, Silverstone LC19
Old February 17, 2012, 05:19 AM
Lian Li Industrial Co., Ltd.
Antec Minuet 350 Enclosure.
Antec.com - Product: MICRO FUSION REMOTE 350
heatware
Old February 17, 2012, 07:17 AM
yamawho's Avatar
I have done this with a Lian Li Q11A, although it accepts 9.6 x 9.6" with modding, it's a better fit with a mobo less than 8" wide. In most cases, you cannot use the hdd tray at the bottom as well.
Old February 17, 2012, 07:32 AM
Arinoth's Avatar
Think I'm kinda in the same boat as you, though I have little to no need for a 5.25" bay or really even a 3.5" slot (got a 2.5" hard drive for my OS)
Old February 17, 2012, 11:23 AM
Dr_BenD_over's Avatar
This might float yer boat
SilverStone Technology Co., Ltd.- LC19
If it's stupid and it works, it isn't stupid.
Old February 17, 2012, 11:39 AM
Arinoth's Avatar
That's a 200$ case, myself I'm thinking of just going with the M350, MINI-BOX M350 Universal MINI-ITX Computer Case Black 1X2.5INT Works With Pico PSU - Black - Mini-Box - M350
Old February 22, 2012, 02:03 PM
TheGomdoRi's Avatar
Originally Posted by zoob View Post
I have that case it's pretty big for mATX tbh, there are smaller Lian Li cube shaped ones that might be better suited for your needs.
Old February 23, 2012, 11:29 PM
tangrisser's Avatar
Have you considered the Silverstone Milo? It's thinner than most and has a nice clean black finish
Silverstone Milo ML03B Black mATX HTPC Case 1X5.25 2X3.5INT USB3 Supports 4 80MM Case Fan - Silverstone Technology - ML03B
Price on this is quite low for a HTPC case. I would highly recommend it.
Check out my SALE page
Old February 25, 2012, 07:19 AM
486's Avatar
486 486 is offline
Default mATX case
I think I should clarify what I am looking for.
I need mATX HTPC case with smallest depth and width dimensions. For that, I think, picoATX PSU (100-200W) required, as regular PSU is too big (who needs 400+W PSU for 35-45W CPU?).
I also think IR receiver integrated in the case is very important, as add on IR receiver dongles simply mess up the look. And not just any IR receiver, the one that is capable of starting / waking PC. Damn, I am picky :)
Thanks for recommendations though. I will consider those cases for sure.
May be I should look into mITX barebones?
Silverstone TJ-08E
Seasonic X-660
Asus P8Z77-M Pro
Intel i7-3770
[WTB] WTB: i7 matx board + matx case Dar_T Buy/Sell & Trade 13 October 27, 2011 09:14 PM
Smallest ATX Case that will fit 5870 and Megahalems FreeKnight Cases 11 December 24, 2010 07:57 PM
2 gtx 460's in the smallest case i can find... SKW Cases 7 October 14, 2010 01:47 PM
Smallest possible MATX spec case b1lk1 Cases 18 March 13, 2010 06:20 PM
case recommendation fruity Cases 21 July 19, 2009 06:43 PM
