Old April 15, 2008, 04:57 PM
Mr. Cipher's Avatar
Might be nice to turn this into a general HTPC guide if we don't have one already.
Not trying to thread-jack, but I thought there was alot of details involved with building ones own speakers, regarding the enclosure, pressure, airflow, cabling etc? Maybe it just appears more daunting to me than it really is in reality.
Also noticed someone mentioned Paradigm speakers - I still have a set of floor-standing speakers that I got in the early 90s and they work great. If they still build them like they did, then you'll definitely have something good there.
i7 Red
EVGA X58 Classy | i7 920 D0 | Megahalems w. 1 noctua push| Mushkin Redline | BFG GTX 295 | 2x640 WD Black | Corsair HX1000 | HAF 932 | Asus 26" LCD
C2Q Blue
Gigabyte EP45-UD3p | Q8400 @ 2.66ghz | Thermalright Ultra 120 Extreme w. Scythe | Mushkin Redline PC2-8000 5-5-5-15-2T @ 400mhz | BFG 8800GTX OC | 1.32TB WD HDDs | Corsair HX 620 W | Antec 900 | Acer 20" LCD
Intel E1xxx & E2xxx OC Thread
Old April 16, 2008, 03:46 AM
lcdguy's Avatar
Originally Posted by dwoods99 View Post
I also got a PCH unit (Popcorn Hour) and looking for a simple solution for the lack of DTS support without an AVR hooked up.
The PCH is hooked up directly to an LCD screen which has RED/WHITE audio (analogue connectors.
I am using HDMI video/audio right now which works for AC3 audio. What I need is a convertor that
accepts the PCH's SPDIF output back to analogue.
unfortunately this a draw back with the current version of the PCH. The reason that you can't play DTS over analogue audio connectors is the PCH can't output DTS to a PCM bitstream. It can only do a passthrough. I think this partially because therer is so much more information in a DTS bitstream than Dolby. What i use is a digital coax to my audio reciever with ac3/dts on raw. Works like a charm.
New Build - Could use some advice nophen CPU's and Motherboards 23 March 14, 2008 07:47 PM
New Build Advice Towndrunk CPU's and Motherboards 5 March 12, 2008 10:28 PM
Very Cool Home Theatre Pic's Robscix HTPC Systems & Software 5 January 31, 2008 04:18 AM
MoDT HTPC Build Log CMetaphor Case Mods, Worklog & Gallery 28 August 2, 2007 06:32 PM
Looking to build a HTPC? Babrbarossa Press Releases & Tech News 0 February 16, 2007 10:51 AM
