-   HTPC Systems & Software (http://www.hardwarecanucks.com/forum/htpc-systems-software/)
-   -   100mbit (http://www.hardwarecanucks.com/forum/htpc-systems-software/49573-100mbit.html)
clshades December 19, 2011 04:32 PM
100mbit
Can't afford the gigi switch I want right now but I'm wondering if 100mbit will run bluray/highdef content? I have a boxeebox upstairs for the video and the file server down in the basement. Currently I have a gigi upstairs but since relocating everything to the basement including ME and my main rig I wanna bring the gigi downstairs for file transfers etc.
So the 100mbit does around 11 megs a second.
Arinoth December 19, 2011 05:05 PM
According to the Blu-ray Disc specification, 1x speed is defined as 36Mbps. However, as BD-ROM movies will require a 54Mbps data transfer rate the minimum speed we're expecting to see is 2x (72Mbps).
source: Blu-ray.com - Blu-ray FAQ
So you should be fine
supaflyx3 December 19, 2011 05:12 PM
Yes 10/100 will be fine for bluray, it might stutter a bit if there's something else using bandwidth though.
clshades December 19, 2011 06:21 PM
Ok thanks fellas. The boxie is pretty much the only thing running up there but it's nice to have the extra connections in a pinch.
Taichan December 22, 2011 04:09 AM
If its a boxeebox, it doesn't have gigabit anyways.
clshades December 29, 2011 12:11 AM
cheers
