<~----> Need to replace my Atom 230... - Hardware Canucks
Old October 21, 2011, 08:54 AM
Dr_BenD_over's Avatar
Default Need to replace my Atom 230...
I orginally bought this thing as a basic file server back be before NAS's came with FTP software on them. Anyway it has evolved into a pseudo HTPC, but it's not even close to being powerfull enough to play back any HD content. What's the cheapest mobo/cpu combo with HDMI output from onboard video/audio I can get that can handle 1080P? I'd like to keep using the DDR2 I've got in it as well.
System now:
Intel D945GCLF w/ ATOM 230
2GB DDR2
HD2400Pro (crippled PCI version )
500GB WD Blue
BFG 550W PSU
TT Shark Case (So I'm obviously not limited to M-ITX)
Audigy 2 NX (2400 doesn't have HD audio)
If it's stupid and it works, it isn't stupid.
Old October 21, 2011, 09:16 AM
supaflyx3's Avatar
Atom 330 with nvidia ion is probably the cheapest you can get, although it'll still set you back $150-200.
Old October 21, 2011, 09:22 AM
Arinoth's Avatar
You could go with the all-in-one solution offered by Pivos, their AIOS. It seems to be able to play every file format and 1080p content I can throw at it. Has FTP possibilities, internal hard drive (or external) if you want to store files on there, browse the web on it, bit torrent client, and much more. The only draw back is it doesnt archive/scan network storage devices so you have to manually navigate to the correct folder, supposedly this will get fixed in the future in a firmware update.
It's around 100$ before taxes (i think they have free shipping with it). Can't really go wrong with that. For the little quirk I found it has, its still an amazing buy at the price.
Old October 21, 2011, 09:38 AM
Wow, I can even use that to check my Facebook status...
I do occasionally use it as a PC when I'm to lazy to walk to the computer room, so that sort of a unit isn't for me.
The 330 is just a dual core version of the 230. I'm thinking along the lines of the newer D510's. WTH is the name of that site that specializes in this sort of stuff?
Replace or renew? martin_jones CPU's and Motherboards 7 September 14, 2010 09:02 PM
Replace HDD? Hunt Storage 11 February 15, 2010 11:33 AM
[WTB] Looking to replace what i lost Beermaster Buy/Sell & Trade 9 October 14, 2009 10:27 PM
Replace GPU sticker... mattlef Off Topic 4 September 28, 2009 07:43 PM
Replace TIM on gtx275? somecanadianguy Video Cards 6 June 19, 2009 10:51 PM
