Old June 30, 2011, 09:57 AM
Default PC to TV?
The pc vid card is x800xl (has s video plugged to tv and vga plugged to pc monitor), OS is win7 64.
What I did is select duplicate monitor to get the tv to play back an avi, what I was trying to do was play the avi on the tv while using the internet on the pc monitor, Is it possible to have two seperate things going on at the same time with out it showing up on both screens, example avi movie on tv and browsing the net on the other pc monitor at the same time?
Thanks.
Gaming FX 8350 4.4GHZ / Tuniq Tower 120/ MSI GTX 1070 Armor / G Skill 32GB / S12D 850w/ GA 990FXA-UD3 /SSD 240GB , WD1TB FALS, 3TB Toshiba / Dell IPS 1920x1080/ Win 10 64
Daily Use x4 965BE 3.4GHZ/GA 970 Gaming/ Rx 580 8GB /EA750w/4x4GB ram/Win 10 64 and 24TB of hdds
Old June 30, 2011, 10:13 AM
Arinoth's Avatar
I know with modern cards you can do that, i'm not so certain with that older card.
Here I am: here I remain
Old June 30, 2011, 10:17 AM
Should be possible, I've done it with my 9800XT which should be an older gen card.
Old June 30, 2011, 10:25 AM
Another question is, what would be the longest s-video or hdmi cable that I could use from vid card to tv?
This is my first attempt at this, right now I have a tv plugged in beside the comp with a 6ft cable for testing but need the tv in another room once I figure it out.
Old June 30, 2011, 10:32 AM
If my memory serves me correctly, for S-Video; 50ft max for normal-quality cable. Up to 100ft if you use good-quality one.
1st - ASUS P8P67 Deluxe, i7-2600K o/c 4.6Ghz, Corsair Vengeance DDR3-1600 16Gig, 2x HIS Radeon 6970 CF, Custom WC from Dazmode, Corsair AX1200, Corsair P3-128 SSD, Coolermaster HAF-X
2nd - ASUS P5B Deluxe/WiFi-AP, Q6600 o/c 3.6Ghz, Corsair Dominator 6Gig, Sapphire 5870V2, Swiftech H20-220 Ultima XT, Corsair AX850, Antec 900
Old June 30, 2011, 10:46 AM
Arinoth's Avatar
I would avoid S-video if you could as it really isn't that great. HDMI I know can go rather far, as I am running a 10M cable myself and have ran cables up to 30M without a repeater required.
Old June 30, 2011, 07:57 PM
Originally Posted by upcoast604 View Post
What I did is select duplicate monitor to get the tv to play back an avi, what I was trying to do was play the avi on the tv while using the internet on the pc monitor.
Extend the desktop instead and drag the avi on the tv and browse the web on the monitor.
Old July 1, 2011, 04:03 AM
MARSTG's Avatar
that card does not have hdmi. dvi only, and yes is possible what you want, but you need to set up the tv with a different resolution, try 640x480 or 800x600. Are we talking about a CRT or LCD?
Old July 1, 2011, 06:41 AM
Arinoth's Avatar
DVI to HDMI cable or adapter easily fixes that.
Old July 1, 2011, 03:50 PM
Ok, so I tested all the TVs and vid cards and all worked with a 12' s-video cable.
Sony 27" and 36" 10yr old glass screen trinitrons need 25' to 30' svideo cable is this good enough to carry a signal 30 feet S-VIDEO CABLE MALE TO MALE 30FT - DirectCanada
