Old July 1, 2011, 04:30 PM
fishingfanatic's Avatar
Smile Hardware
DVI to HDMI works if u have another connection for audio, like fibre optic. Either that, or pc speakers. I used both, and prefer the DVI and fiber optic.
HDMI is obviously the way 2 go, but the dvi/fiber optic option works well with my surround sound system. Perhaps look at a tv card, which aren't that much money.
Edit: Isn't the S Video cable only video, which needs another cable 4 audio Arinoth? Seems 2 me I had a 2nd cable 4 audio in that case, which if I remember worked pretty good with older setups.
It's been a while since setting up 1 of those.
Old July 1, 2011, 07:02 PM
To everybody, thank you for all the help.
I just tried the "extend desktop and drag" it worked.
I'm doing the 2 older tv s with s-video(x800xl for one/ 1950Pro for other) and the newer 46" lcd with a dvi-d to hdmi 25' cable (8800GTS).
Again thanks.
Ps,yes, s video needs seperate audio cables but I've got lots of them.
Gaming FX 8350 stock / Tuniq Tower 120/ MSI GTX 1070 Armor / G Skill 32GB / S12D 850w/ GA 990FXA-UD3 /SSD 240GB , WD1TB FALS, 3TB Toshiba / Dell IPS 1920x1080/ Win 10 64
Daily Use x4 965BE 3.6GHZ/GA 970 Gaming/ R7 265 1GB /EA750w/4x4GB ram/Win 10 64 and 24TB of hdds
Old July 1, 2011, 08:56 PM
BAM! Sometimes the simplest thing works the best. Surprised no one suggested it before me.
Glad it works!
Old July 2, 2011, 01:24 PM
ipaine's Avatar
That is exactly what I used to use back in the day before I used a dedicated HTPC. Even used a 50 foot s-video cable. Of course that was to an older non HD tv.
"Nothing sucks more than that moment during an argument when you realize you're wrong."
