<~----> HTPC and Starchoice HD - Hardware Canucks
Old April 19, 2011, 12:36 PM
Wi-Fuzzy's Avatar
Default HTPC and Starchoice HD
I have not read much about this lately. Is there now a way to record TV shows from a Starchoice HD reciever? I looked into this a year or so ago and the answer was no.
Old April 19, 2011, 12:47 PM
SugarJ's Avatar
It depends if the receiver requires a HDCP compliant device. Hauppage just released the Colussus with HDMI input, but if your receiver requires a HDCP monitor, it won't work.
Review here: Hauppauge Colossus: HD PVR with HDMI Support - AnandTech :: Your Source for Hardware Analysis and News
Old April 19, 2011, 01:37 PM
Wi-Fuzzy's Avatar
Ya..I read it before. My reciever is about 1 1/2 years old, can't remember the model #. It does have a dvi out...but I think that is useless in this case.
edit: could I just get an adapter and convert the DVI to HDMI? That would not have HDCP....?
Old April 19, 2011, 02:08 PM
lowfat's Avatar
I've been recording Shaw Direct/Starchoice high def for nearly three years now w/ an Hauppauge HD PVR. At first i used BeyondTV but switched to SageTV 7 around Christmas. BeyondTV was crap as was the older SageTV. Both had horrible hd PVR support. SageTV 7 is much better though. I've only had one screwed up recording this year versus 5-6 per week.
There is no need to use hdmi. It offers nothing over component and spdif besides a smaller cable.
Old April 19, 2011, 02:52 PM
Wi-Fuzzy's Avatar
Every year I think about that doing this. And every year I just keep downloading them. It's Just as fast and the picture quality seems to be better. I guess the geek in me wants to make it work.
Old April 19, 2011, 03:39 PM
SugarJ's Avatar
If you don't have bandwidth issues, that's the easiest fix.
Old April 19, 2011, 03:41 PM
lowfat's Avatar
Downloaded media is definitely not higher quality. If is highly compressed. An hour of recorded tv for me is around 10 Mbit/s while downloaded rips are around 5. Quality definitely isnt twice as good but it definitely is better.
Are you hooking up the cable box to the tuner?
Old April 19, 2011, 03:48 PM
lowfat's Avatar
Hd PVR is just a capture card. But yes. Receiver is connected to Hauppauge HD PVR via component and SPDIF. SageTV automatically chances channels via ir blaster on HD PVR.
Old April 19, 2011, 03:51 PM
Supergrover's Avatar
You must be using Shawsbox to the hd-pvr correct?
If so then I imagine you are limited to recording and watching one channel at a time correct?
Been wondering since I use a shaw pvrbox for my HD downstairs but for the life of me have never got it to connect to my network. I hardly ever watch anything downstairs so it doesnt get used much. And I have been looking for a solution that would allow me to watch record multiple channels at the sametime across the network at the sametime.
Sorry to the OP for derailing the topic.
R.I.P.
new htpc Haiden New Builds 6 November 3, 2010 09:17 PM
[FS] HTPC Squeetard Buy/Sell & Trade 1 May 29, 2010 04:33 PM
HTPC Help Burkdaddy New Builds 8 July 23, 2009 06:14 AM
HTPC OS? biff HTPC Systems & Software 25 February 26, 2009 06:09 PM
Tuner for Starchoice? lowfat HTPC Systems & Software 18 September 3, 2008 03:09 PM
