Originally Posted by Eldonko I cant get mkv to play with wdtv. I have to convert them to avi or similar. |
Originally Posted by Shadowmeph I use a free converter like DeVeDe to convert vids to DVD.
as for the .mkv's like everyone else has said I also convert them into a different formate because my media player doesn't play them. there are allot of free video converters out thereI use a couple of different ones like format factory if I have a few avi files to be added to each other and I use super which is good at converting different video formats but the thing about super is to find the dam download link lol. |
I don't know what you are using Shadowmeph, but the wdtv should play mkv files.
I also used the patriot box office and everything was smooth. Now I am using a htpc so it is different.
OP, if you are thinking about building a little digital collection, I would stongly recommand to not convert everything to dvd and or burining all that. You should consider streaming solutions.
