Old March 29, 2011, 09:45 PM
Andy's Avatar
Originally Posted by Shadowmeph View Post
I should actually correct what I said it does play them but the volume is very low on allot of the mkv files and when you go to the next file and forget to turn the volume down the ear drums can get punished a bit hehe
You could always downmix the audio to stereo via handbrake ... i've had to do that a couple times for the odd person that had a similar issue .... Takes time though.
SAGER 5165 - Matte Screen (1920x1080) - i7-2630QM - nVidia 555M - 8Gb DDR3 - 120Gb Corsair Force GT SSD - 500Gb Momentus XT - Intel® 6300
How to Format a HDD with the OS on it? TokeR Guides & How-to's 9 June 23, 2012 07:37 AM
LG BD350 and MKV to Mp4? mattlef HTPC Systems & Software 8 August 24, 2011 09:49 PM
DVD9 playback and how to convert into mkv? Arinoth HTPC Systems & Software 3 October 17, 2010 01:53 PM
Will the following setup play 1080p Mkv CY:G HTPC Systems & Software 8 March 6, 2009 08:12 PM
