Old March 28, 2011, 05:57 PM
biff's Avatar
Default Problem with DVDshrink re-author
Not sure if this is the best place for this but I figure someone here must be doing this.
I'm using DVDshrink to reauthor my DVD rips into individual episodes for importing to mediaportal TVseries. When I re-author and 'back-up' the disk, I get no video when I play it back (using TMT). The audio works fine though. I set it to no video compression FWIW.
Thanks for any help.
i7 4790K @ 4.8GHz w/EK Supremacy Evo
MSI z97 Gaming 5
2x 8GB Gskill Sniper 2133 @ 2400MHz
EVGA GTX 280 (SC?)
OCZ Gamer Xtreme 600W PSU
Still rockin' the Cooler Master Cosmos on water
Old March 28, 2011, 06:21 PM
Varroa's Avatar
DVD shrink is WAY too old now a days, try something more modern like anyDVD.
GAMER: Win10 Pro x64, I7 3770K (4.7Ghz) (corsair H110i), Asus P8Z77-V Pro, EVGA GTX 1080 FTW, Gskill 2 x 8 GB DDR3 1600Mhz, Crucial M4 120 GB + 256GB, Crucial M500 480 GB SSD, Mx 500 SSD, HX750W, Sound blaster Z, & Fractal Design Arc MIDI R2
Lenovo Ideapad Y510p: i7-4700MQ 2.4GHz (undervolted by 80mV), 16GB DDR3L-1866MHz, Intel GMA 4600HD / SLI'ed Nvidia Geforce GT 755M 2GB GDDR5, 240 GB Crucial SSD, 128GB M.2 SSD, 15.6" HD+ Glossy LED
Old March 28, 2011, 06:49 PM
biff's Avatar
I have anyDVD but I don't see anything in it that would suggest it does DVD reauthoring.
MSI z97 Gaming 5
EVGA GTX 280 (SC?)
Old March 29, 2011, 05:23 AM
Varroa's Avatar
My bad, I mean CloneDVD (same guys that make AnyDVD). You can re-author (removed subs, languages, shrink, etc).
Old March 29, 2011, 08:19 AM
I use DVDFab, I think there is a 30 day trial of it from their website. You can split Episodes into seperate files... I think thats what you are looking for? And it converts into most popular formats mkv, mp4, avi etc... Also choose your bitrate or fixed file size, remove subs, burn subs in, change format ratio (not sure what the technical term is there but say 480, 720, 1080) and sample twice (takes twice as long to process for a bit better quality)
Old March 31, 2011, 10:44 PM
biff's Avatar
Thanks I'll look into that, but I'd really like to end up with a DVD .iso at the end of it. I use TMT as an external player, so I can play my BD stuff too. Funny that DVD's are such a bitch to deal with compared to BD's when trying to do this given the amount of time DVD's have been around. The nice thing about the DVDshrink processing is it takes about 10 to 15 seconds to do which is a real bonus since I got a box load of TV series on DVD's that I'd like to put on my HTPC's. FWIW I can see the video as DVDshrink is doing the processing and the final file size matches what I started with so I have to assume all the data is there, It just doesn't play right. There's not a lot of options to go through in that software, but maybe there is something I'm missing?
MSI z97 Gaming 5
EVGA GTX 280 (SC?)
could this be a game problem or a video driver problem? Shadowmeph Troubleshooting 4 December 17, 2010 07:01 AM
Do you see problem here? Dazmode Water Cooling 19 November 20, 2010 05:43 AM
Hardware problem or HAL problem? andynerd Troubleshooting 1 March 7, 2009 09:03 PM
Little problem... AnthraxAdrian RAM 7 June 24, 2008 02:41 PM
problem... omgwtf Troubleshooting 35 May 15, 2007 08:06 PM
