-   HTPC Systems & Software (http://www.hardwarecanucks.com/forum/htpc-systems-software/)
-   -   Windows MC remote questions (http://www.hardwarecanucks.com/forum/htpc-systems-software/41130-windows-mc-remote-questions.html)
biff February 25, 2011 10:31 PM
I have used remotes before with HTPC's, I have a thermal take DH101 with IMON (yeah I know) and have a Harmony remote with that too. Anyway I just got a Win MCE remote and IR receiver for another setup - well I got it a while ago and I'm just getting it out of the box. Anyway I see there is no software with it.... which has me somewhat confused. I don't see any manufacturer info anywhere but judging by the look of the box and remote it looks like 'official' M$ gear. Anyway am I expected to know where to go get the software? or did I just not receive it? Is there third party software?
JD February 25, 2011 11:08 PM
Assuming you have Windows 7 Home Premium/Ultimate, or XP Media Center Edition, you don't need any software. It simply "works". Although obviously only with Media Center. You have no ability to program buttons and such.
I think there might be some 3rd party programs/drivers out there that can make MCE-compatible remotes programmable though.
biff February 26, 2011 01:35 PM
Yeah I have no intentions on actually using MCE, I use Mediaportal. IMON lets me assign different functions to the buttons depending on what the active application is. For example when I start to watch a movie - which launches TMT - my remote buttons are remapped automatically and I'd like the same functionality. Theres' probably a way around it but this makes setup pretty easy. I just wanted to make sure I got everything I was supposed to get. I'll have a look into third party software. Thanks.
JD February 26, 2011 04:10 PM
Well I use MediaPortal as well with a MCE remote. Assuming you have a Windows version that supports MCE, you'll be fine.
In MediaPortal you can map the buttons to whatever you choose.
JMCD February 26, 2011 06:27 PM
x2, it works perfectly for me in MP. Using Windows 7.
biff February 26, 2011 09:05 PM
Yes I know, but I can't do that in TMT. On my current setup (with IMON) I've gotten everything working except I can't make the 'Exit' button on my remote shutdown TMT. The IMON software lets me remap all the buttons on a MCE remote, which my Harmony is emulating, except my exit button but thats' probably because an MCE remote doesn't have an exit button...
Gah! this is turning into a mess. Maybe I'll try taking out IMON and using an MCE remote straight up and see how TMT reacts with that. TMT was made to be a plugin to MCE so it would make sense that it was also designed to work with the MCE remote. There's got to be a way to exit TMT with the MCE remote. I've been doing a bit of googling and found lots of frustration and bitching so far but no solutions yet.
