<~----> Sandy Bridge Mini ITX build - Hardware Canucks
Old January 21, 2011, 10:22 PM
Default Sandy Bridge Mini ITX build
This is the proposed build, what do you think? I have a Sapphire 6950 and a Seasonic 620w modular PSU along with Windows 7 64 bit.
LIAN LI PC-Q08B Black Aluminum Mini-ITX Tower Computer Case Item #: N82E16811112265Return Policy: Standard Return Policy
-$19.00 Instant
$128.99$109.99 select item 2 quantity of item 2
Mushkin Enhanced Silverline 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model 996770 Item #: N82E16820226095Return Policy: Memory Standard Return Policy
$82.49 select item 3 quantity of item 3
Intel BOXDH67CF LGA 1155 Intel H67 HDMI SATA 6Gb/s USB 3.0 Mini ITX Intel Motherboard Item #: N82E16813121484Return Policy: Standard Return Policy
$124.99 select item 4 quantity of item 4
Intel Core i5-2500 Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor BX80623I52500 Item #: N82E16819115073Return Policy: CPU Replacement Only Return Policy
$214.99 select item 5 quantity of item 5
Scythe Big Shuriken SCBSK-1000 120mm CPU Cooler
$33.99
Old January 21, 2011, 11:14 PM
SugarJ's Avatar
It's fine if you aren't interested in overclocking.
No graphics card?
Old January 21, 2011, 11:16 PM
I guess you missed the second sentence stating I have a Sapphire 6950 to put in it.
Old January 21, 2011, 11:19 PM
SugarJ's Avatar
Whoops, I sure did. It's been a very long day. That will be a great SFF/portable build.
Old January 21, 2011, 11:29 PM
Thanks.
The 6950 has the BIOS flashed to 6970 specs too and it clocks to the 6970 speeds without any issues.
I am very tempted to hit the Pay Now button.
Old January 22, 2011, 05:11 AM
botat29's Avatar
Are you sure your cooler will clear the GPU, I have hard time to find a cooler for my Gigabyte H55 mini-itx, and this board look similar in the cpu-gpu position
You gone have to mod ( cut) the bottom part of the HD cage to accommodate the 6970 , easy mod, but still have to be done.
Old January 22, 2011, 05:55 AM
i know it may not interest you right now, but when the oc bug hits you? you'll be looking at a k cpu and a p67 or h68 mobo
to play with.
the core parts you chose are good, so gl with the build!
Old January 22, 2011, 09:22 AM
chubaka's Avatar
to play with.
no mitx p67 board as of right now. Gigabyte is rumored to have one...soon.
Old January 22, 2011, 11:25 PM
I am not sure that this little system will even need overclocking, I think it will be a very capable games machine.
I thought the 6950 would fit without any mods as its less than 300mm in length which is the maximum according to Lian Li.
Old January 23, 2011, 12:12 AM
chubaka's Avatar
560 is out.Worth considering IMO
Sandy Bridge Gaming Build impruv New Builds 12 January 24, 2011 06:18 AM
Ordering tonight - new build - sandy bridge elimtl New Builds 19 January 22, 2011 04:15 PM
My Sandy Bridge Build Eluder New Builds 24 January 17, 2011 05:42 PM
1st ever build now or wait for sandy bridge? tl9015 New Builds 25 December 2, 2010 12:34 PM
Lian Li Launches PC-Q08A/B/R Mini Tower Chassis for Mini-ITX and Mini-DTX FiXT Press Releases & Tech News 1 April 29, 2010 09:17 PM
