Blu-ray iso lag I'm having some lag when I play my blu rays. I thought at first it was my network, yet i have a gigabit network. Could've been my "week" latop, but even a big blu ray (stocked on my local hard drive) lags on my desktop (quad, 5770).. I'm using powerdvd 10, I don't remember having this kind of lag .. Does anyone have an idea of what could cause this lag? |
Make sure in power dvd settings under video.. enable hardware acceleration is checked that could be your problem |
I don't really have anything to add except to rule out the network. I've tested playing a bluray across my 100MB network and only got to 40% max usage. I'm using TMT though and only an Athlon II. Gotta be some setting. Whats the task manager say for network, CPU, etc. usage when trying to play it? |
only thing i could suggest is try vlc player and see if it does it too. with gpu acceleration and with out. cause that cpu should be able to handle it pretty easy. |
When streaming from my home server, the network got a spike at ~10% when fast forwarding.. but is somewhere aroung 5% on normal movie streaming. But It ain't the problem since even when the movie is local it does the same lag. The CPU never went over.. something like 7-8%... maybe less. RAM? I don't think it uses 1-2% more when watching the movie. Hardware acceleration was enabled, I'll try without it. (dunno why, but i'll still do..) ~Thanks for your help |
| All times are GMT -7. The time now is 02:37 AM. |
