Old December 11, 2010, 01:42 PM
scruff's Avatar
Default xbmc help
Hi gang
I have been trying to set up xbmc on my htpc to try it out but it say's that I am missing d3dx9_42.dll ,
I have downloaded it a couple of times and reinstalled it several times with no luck. any ideas would sure be apreciated .thanks
Old December 11, 2010, 03:39 PM
Arinoth's Avatar
What version of xbmc are you trying to install, what is the operating system you are using, and what are the system specs?
Old December 12, 2010, 10:20 AM
scruff's Avatar
It's ver 9.11 on Win 7 Home Premium x64, 4 gb ram ,5770 , I3 550 , gigabite mobo., Lian-Li PC-C34F, 3 WD Green 2TB storage , Phoenix pro 60GB ssd for operating system. I know it's got to do with directx but when I go to Microsoft and try to reinstall directx I get directx error messages and it won't install. ( clean install ????)
Old December 12, 2010, 12:51 PM
Deeival's Avatar
Let me google that for you
XBMC Android remote mattlef HTPC Systems & Software 7 October 7, 2010 08:25 AM
XBMC/Network help p3t3rson HTPC Systems & Software 5 August 8, 2010 06:14 PM
XBMC Advice Arinoth HTPC Systems & Software 29 July 28, 2010 07:58 AM
XBMC wifi p3t3rson O/S's, Drivers & General Software 1 March 9, 2010 10:37 AM
XBMC in all its beauty. lowfat HTPC Systems & Software 27 September 18, 2009 05:22 PM
