  #31 (permalink)
Old December 13, 2010, 09:37 AM
WAIT
actually i would hold off on the dell. Read this page, How to: Build your own Gyration Media Center remote - Hack a Day they talk about it. it was originally sold with a dell model computer and dell rewrote the drivers differently then gyration and i thing you need another peice of hardware to run the dell remotes(or that what that big reciever thing is)
the gyrations just have a simple dongle. research the hell out of it if you consider the dell model, i dont want you to get trash with my reccomendation
  #32 (permalink)
Old December 14, 2010, 01:25 AM
Blu's Avatar
Blu Blu is offline
I can't really find much on that remote so I think I'm just going to go with this,
NCIX.com - Buy Logitech Dinovo Mini MCE HTPC Wireless Keyboard Backlit Bluetooth 30FT Range LI-ION - 920-000595 In Canada.
And I bought the shell shocker deal wireless keyboard and mouse from newegg as well, was a great deal both for $28 bucks with free shipping. It will let me play around with windows 7 a bit as I've never used it before and am just planning to use it for my HTPC and want to go legit so I never need to worry about updates and all that.
  #33 (permalink)
Old December 19, 2010, 12:52 AM
Blu's Avatar
Blu Blu is offline
Ok guys I'm sort of at a cross roads here, I don't know what to buy.
I wanted to buy this gigabyte 880gm because it already had HDMI outpu and the works, just less sata ports then I needed, which I already solved by purchasing a PCI Sata card and I can price match the board for $95 bucks. (Also will a pci card work in a pci express 4x slot?)
NCIX.com - Buy Gigabyte 880GMA-UD2H AMD880G mATX AM3 DDR3 1PCIE CrossFireX DVI HDMI GBLAN SATA3 USB3.0 Motherboard - GA-880GMA-UD2H In Canada.
OR
I can get this board for $97 PLUS Free shipping and it already has enough sata ports that I need and has more then enough PCI slots for adding on, but I will need a low end graphics card for the HDMI port (Does sound still travel through a HDMI port on a graphics card?)
Newegg.ca - GIGABYTE GA-870A-UD3 AM3 AMD 870 SATA 6Gb/s USB 3.0 ATX AMD Motherboard
What should I do?...Go mATX cause I want a nice clean case or full ATX to get all the slots I want without needing extras?
Also I don't really see these going on sale for boxing day so I sort of thought about buying them now instead of waiting :(
  #34 (permalink)
Old December 24, 2010, 05:20 PM
Blu's Avatar
Blu Blu is offline
Ordered all the parts, should be all here within the next 2 weeks or so. The fan cable is going to take the longest to get here but oh well....excited to open my cpu though. hope I can unlock it to a quad :D
  #35 (permalink)
Old February 9, 2011, 04:29 PM
jangyman's Avatar
Blu, stop watching movies for moment and let us know how your setup went. Did you get quad unlocked? Did you have to change any components?
Sorry, I don't do well with cliff-hangers.
HTPC: ASUS P7H55-M PRO mATX | Intel i3 550 | LG CH10LS20 SATA Blu-ray
Case: nMedia HTPC-1000B (on order)
New HTPC Build nwboater New Builds 3 October 31, 2010 08:55 AM
HTPC build Kerry D HTPC Systems & Software 15 September 22, 2009 07:27 AM
HTPC build help? 3.0charlie HTPC Systems & Software 11 October 4, 2008 02:14 PM
Yet another HTPC build- help? misterd HTPC Systems & Software 4 August 1, 2008 10:10 AM
HTPC Build Phobia HTPC Systems & Software 15 July 16, 2008 10:07 AM
