Old December 29, 2007, 06:49 PM
Default starting HTPC
Hi, iam currently trying to start a HTPC. At the moment i have a 5.1 surround sound speaker system in my room.
Iam thinking of connecting my PC to LCD TV via VGA (or any other better methods?) so i can play music, view DVDs, downloaded movie clips, etc on the LCD TV instead of my small PC monitor.
Just wondering how would i be able to hook up the surround sound system to my PC, would i need to use a receiver, amp etc, and what type of sound card (atm i have AC99) is needed, would i require HD Audio? I have Mission & Klipsch speakers + Velodyne sub.
Old December 29, 2007, 08:01 PM
Babrbarossa's Avatar
yes- unless you have internal or integrated amplifiers in your speakers, you need an amplifier
psst, wanna see my binder?
Old December 29, 2007, 09:59 PM
thanks for your reply, can the home computer act as a receiver/amp ?
Old December 29, 2007, 10:12 PM
BALISTX's Avatar
Yes the PC can act as a receiver, it would be similar to having your PC speakers connected to your computer. However if you already have a home theatre receiver I recommend you use that. Most new receivers have optical in and most newer motherboards that are being used as HTPC have an optical out. If you have an older receiver you could always get a 3.5mm to RCA cable to run from the Line out on the onboard sound to your receiver.
"Though I walk through the shadow of the Valley of Death I shall fear no evil as my C8 Carbine is locked and loaded."
Next Build: E5200 @ 3.6GHz (333x11) | Xigmatek HDT-RS1283 HSF | Biostar TP43D2-A7 | Mushkin Redlines DDR2-1000 @ DDR2-999 5-5-5-12
EVGA 9600 GT 512MB - 650MHz - 1800MHz - 1626MHz | Seagate 'Cuda 250GB 7200rpm SATA2 | Corsair VX550 | CM690 - Custom Atomic Orange Pearl
[Heatware]
[eBay]
[Rosetta]
BALISTX.com
Old December 29, 2007, 10:23 PM
can i used 3.5mm to RCA cable and run it straight to the speakers.
also what if the speakers i have has stripping cables, so how would i connect the speakers to PC, does this mean that i must use a receiver?
Old December 29, 2007, 10:26 PM
BALISTX's Avatar
In that case you would need to use a receiver. You can usually find a good deal on ebay or even check out Craig's List in your local area.
[Heatware]
[eBay]
[Rosetta]
BALISTX.com
Old December 30, 2007, 05:11 AM
sswilson's Avatar
The signal coming out of a computer is extremely low amplification and can't drive large speakers.
If it's going to be in a smaller room, you can probably pick up a decent set of powered computer surround speakers to do the trick, but for a larger room you'll want to use a receiver.
Old December 30, 2007, 10:28 AM
JD JD is offline
So you have this high-end speakers and no receiver? So these speakers are just sitting there collecting dust?
I think you'll want a decent 5.1 or 7.1 receiver to drive those speakers. Maybe something from Harmon Kardon, Denon or Yamaha.
Then assuming your motherboard has SPDIF out, then you get a cable for that to plug into the receiver giving you digital sound.
I had issues using VGA on my Sony LCD TV. It would run 1400x1050 maximum or something, aka a square box. I had to get a DVI-to-HDMI cable so that I could run my HTPC in full 1080p (1920x1080).
Old December 30, 2007, 05:41 PM
Hi, yeah, these speakers are just sitting there now. i haven't not got around to buying a new receiver yet (my last one was bought in the early 90s). I just thought it would be better if i could use the PC as the receiver/amp
Old December 30, 2007, 05:48 PM
just wondering, if i used a Alienware Hanger 18 HTPC, could i use this as the receiver and not plugging in an external receiver?
Alienware: Hangar18 HD Home Entertainment Center Learn More!
Show me your HTPC Croman HTPC Systems & Software 38 September 23, 2008 09:31 AM
HTPC Motherboard MaDDN3ss CPU's and Motherboards 6 January 28, 2008 05:27 PM
HTPC recommendations lcdguy HTPC Systems & Software 7 December 19, 2007 11:11 PM
Budget HTPC BALISTX HTPC Systems & Software 4 May 28, 2007 08:16 AM
