Old October 28, 2010, 03:56 PM
LionRed's Avatar
Sheesh my HTPC idles at 54Watts. Maybe 150Watt with HD movies playing.
They say you can tell how rich a man's life has been, by how many dogs he has had in it.
RIP Kiwi - Oct 19th/05 - April 18th/11, you will always be our puppy!
Old October 28, 2010, 04:15 PM
Ok. I found a case that uses a full ATX psu...
LIAN LI Black Aluminum PC-C37B Micro ATX Media Center / HTPC Case
I don't have a link (on the bb atm) but it's on newegg's website for about 3x the price.
As far as your rig, Lionred: What are you running? Is it comparable to mine?
Old October 28, 2010, 05:41 PM
JD JD is offline
I'd go with a 880G or 890GX motherboard instead personally. Shouldn't cost too much more either.
You can drop the CPU down to a Athlon II series instead. Things like the 240, 250, 255, etc. No need for the Phenom series.
Don't really need DDR3-1600, but it probably won't net much savings. DDR-1333 is more than sufficient.
PSU wise, I wouldn't trust Thermaltake to be absolutely silent. Stick to Corsair or Seasonic I'd say.
Or go with 3.0charlie's recommended case (Newegg.com - Antec MicroFusion Remote 350 Micro ATX Media Center / HTPC Case) as it has a solid Antec PSU which should be silent, along with a remote so you can scrap that from your list.
And I highly doubt any combination of dual-core AMD + motherboard w/ integrated graphics would ever exceed 200W. I'd be surprised if it exceeded 100W in normal usage.
Old October 29, 2010, 03:25 AM
The processor chosen is 80W. I wanted to go with a decent processor but not one of those 125W quad cores.
That case is ok but I'm looking for 100% black. I guess you can say I'm a racist. ;). And that remote is like the remote you get for a car stereo.
The case can be 4.5" tall max and that limits my selection.
Old October 29, 2010, 05:24 AM
Synth's Avatar
I would stick with the X2 555 you selected if you plan to do CPU intensive stuff like encoding video/music, since it has a pretty good chance of being unlocked to a quad. A 80w quad is pretty sweet!
If you only plan on doing media playback on your HTPC, an Athlon II (like an x2 250) will be more than sufficient though.
Old October 31, 2010, 11:18 AM
Components ordered.
Old November 8, 2010, 12:00 AM
KaptCrunch's Avatar
your missing the most important thing to HTPC........audio
you have av receiver that will handle fiber optic/coxial digital and a good sub woofer, some models offer dual stations (play tuner in another room while watch movie)
My first HTPC Build demarderozan HTPC Systems & Software 2 February 24, 2010 11:19 AM
Help me pick out some htpc components 0o0 HTPC Systems & Software 7 February 12, 2010 10:47 PM
Proposed Sims2/3 Build Kasie23 New Builds 46 March 11, 2009 09:10 PM
Possible HTPC build lcdguy HTPC Systems & Software 29 November 18, 2008 11:42 AM
Yet another HTPC build- help? misterd HTPC Systems & Software 4 August 1, 2008 10:10 AM
