-   HTPC Systems & Software (http://www.hardwarecanucks.com/forum/htpc-systems-software/)
-   -   DVD9 playback and how to convert into mkv? (http://www.hardwarecanucks.com/forum/htpc-systems-software/37161-dvd9-playback-how-convert-into-mkv.html)
Arinoth October 16, 2010 07:03 PM
I was wondering what programs will playback dvd9 ISOs? It seems VLC wont and a quick google search hasn't yielded and help either.
JD October 16, 2010 07:29 PM
Can't you mount the ISO with say VirtualCloneDrive and then just play it like a normal DVD?
werty316 October 16, 2010 07:50 PM
Try Media Player Classic Home Cinema else mount it using Virtual CloneDrive.
Arinoth October 17, 2010 01:53 PM
Well that didnt seem to work nor does xbmc like them, going to have to find what ones are dvd9 and change them to mkvs some how
